Learn how to seamlessly share your Tumblr posts on Blogger using Pabbly Connect. This tutorial covers step-by-step integration and setup. Develop expertise in application integration and learn how to design streamlined automation workflows using proven, simplified approaches.
1. Accessing Pabbly Connect for Tumblr to Blogger Integration
To share Tumblr posts on Blogger, you first need to access Pabbly Connect. Start by visiting the Pabbly Connect landing page at Pabbly.com/connect. Here, you will find options to sign in or sign up for free.
If you are a new user, sign up for a free account to access 100 tasks every month. Existing users can simply sign in to their dashboard. Once logged in, click on the ‘Access Now’ button to enter the Pabbly Connect interface.
After accessing Pabbly Connect, you will need to create a new workflow. Click on the ‘Create Workflow’ button, and you will be prompted to name your workflow. Name it ‘How to Share Tumblr Post on Blogger’ and select the folder where you want to save it.
- You will now see the trigger and action setup window.
In this window, you will define the trigger as Tumblr and the action as Google Blogger. This setup is crucial for automating the sharing process.
3. Setting Up Tumblr Trigger in Pabbly Connect
To configure the trigger, search for Tumblr and select it as your trigger application. Choose the event ‘New Post in My Blog’ to initiate the workflow when a new post is created in your Tumblr account. using Pabbly Connect
Click on ‘Connect’ to link your Tumblr account. If you have not connected your Tumblr account yet, select ‘Add a New Connection’ and follow the prompts to allow necessary permissions. Once connected, specify the type of post you want to share, such as ‘Photo,’ and select the appropriate blog.
- Click on ‘Save and Send Test Request’ to capture the latest post.
- Ensure that Tumblr is set to check for new data every 30 minutes for efficient automation.
After successfully capturing the response, you are ready to move on to the action setup.
4. Configuring Google Blogger Action in Pabbly Connect
Next, you will set up the action to publish the Tumblr posts on Blogger. Search for Google Blogger and select it as the action application. Choose ‘Create a Post’ as the action event to publish the content automatically. using Pabbly Connect
Again, click on ‘Connect’ to link your Google Blogger account. If prompted, sign in with your Google account and grant the necessary permissions for Pabbly Connect to access your Blogger account. Select the correct blog ID where the posts will be published.
Map the title and content from the Tumblr trigger response to the Blogger action. Set the post status to draft or live, depending on your preference.
Once everything is configured, click ‘Save and Send Test Request’ to ensure that the post is published on your Blogger account.
5. Finalizing and Testing Your Workflow
After setting up both the trigger and action, it’s time to finalize your workflow. Review the settings to ensure that everything is correctly mapped. This includes checking the title and content fields to verify that they reflect the latest Tumblr post.
Once satisfied, click on ‘Save and Send Test Request’ one last time. If successful, you will see a confirmation that the post has been created on Blogger. You can then navigate to your Blogger account to verify that the post appears as expected.
Refresh your Blogger page to see the newly published post. Check the content formatting to ensure it matches what was posted on Tumblr.
With this, your workflow is fully operational, allowing you to share Tumblr posts on Blogger automatically through Pabbly Connect.
Using Pabbly Connect to share Tumblr posts on Blogger streamlines your blogging process. This tutorial has guided you through each step, ensuring that your content is automatically published across platforms. Enjoy the efficiency of automated posting!
