Learn how to automate sharing Blogger posts to WhatsApp using Pabbly Connect without any coding. Follow this step-by-step tutorial for seamless integration. Learn to create powerful connections between your critical applications without requiring specialized programming knowledge or extensive technical background.
1. Accessing Pabbly Connect for Blogger and WhatsApp Integration
To start sharing Blogger posts to WhatsApp automatically, you need to access Pabbly Connect. Begin by typing the URL Pabbly.com/connect in your browser. This will take you to the Pabbly Connect landing page.
Once there, you will see options to either sign in or sign up for free. If you are a new user, click on the ‘Sign Up’ button to create an account. This process is quick and grants you 100 free tasks to explore the platform. Existing users can simply log in to their accounts.
After logging into Pabbly Connect, the next step is to create a new workflow. Click on the ‘Create Workflow’ button. A dialog box will prompt you to name your workflow. For this integration, name it ‘Share Blogger Post to WhatsApp Automatically’.
- Click ‘Create’ to proceed to the workflow setup.
- Select Google Blogger as your trigger application.
- Choose ‘New Post Added’ as the trigger event.
This setup ensures that every time a new post is published on your Blogger account, it triggers the workflow to share the post on WhatsApp.
3. Connecting Google Blogger and Google Sheets
Now that your trigger is set, you need to connect Pabbly Connect with your Google Blogger account. Click ‘Connect’ and choose ‘Add New Connection’. Sign in with your Google account and allow access.
Once connected, you will need to create a new post in Blogger. For example, title it ‘Latest Advancements in IT Industry’ and publish it. After publishing, return to Pabbly Connect and toggle the mapping button to enable data mapping.
- Copy your blog ID from the newly created post.
- Paste it into the mapping field in Pabbly Connect.
- Select ‘Live’ for the status to ensure only published posts are shared.
Click ‘Save and Send Test Request’ to confirm that the setup is working correctly. You should receive a response containing the blog URL and other details.
The next step involves sending the blog post to WhatsApp. First, connect to Google Sheets in Pabbly Connect to fetch the phone numbers of your contacts. Choose ‘Get Rows’ as the action event and connect to your Google Sheets account.
Once connected, select the relevant spreadsheet containing your contact details. Map the range of data you want to use, for instance, from A2 to C26. Click ‘Save and Send Test Request’ to retrieve your contact information.
Toggle to advanced response to get a detailed array of user data. Add an Iterator feature to segregate values for individual messages. Map the phone numbers correctly in the WhatsApp message setup.
This ensures that each contact receives the message with the correct link to the new blog post.
5. Finalizing the Integration to Send WhatsApp Messages
To complete the integration, add an action step where you connect to the Interact app via Pabbly Connect. Choose ‘Send WhatsApp Template Message’ as the action event. You will need to connect your Interact account by providing a secret key.
Once connected, you can map the phone numbers and customize the message template. Use variables for dynamic content, such as the blog title and link. After setting everything up, click ‘Save and Send Test Request’ to send a test message.
Ensure all fields are correctly mapped, including country code and phone number. Check the message format to ensure clarity and engagement.
After sending the test message, verify it on WhatsApp to confirm the integration works as expected. This completes the automation process, allowing you to share Blogger posts seamlessly.
In this tutorial, we explored how to share Blogger posts to WhatsApp automatically using Pabbly Connect. By following these steps, you can easily automate the sharing process without any coding, ensuring your audience stays updated with your latest posts.
