Learn how to set up a webhook inside Sendy using Pabbly Connect to automate your email marketing processes with WhatsApp and other applications. Discover hidden automation capabilities within your existing tools. This guide shows you how to connect your essential applications and permanently eliminate redundant manual processes.
1. Setting Up Pabbly Connect for Sendy Integration
To set up a webhook inside Sendy using Pabbly Connect, you will first need to access your Pabbly Connect account. This platform serves as the integration hub that allows you to connect Sendy with various applications like WhatsApp, Google Sheets, and Slack.
After logging into your Pabbly Connect account, you will initiate a new workflow. Select Sendy as your trigger application and define the trigger event based on your needs, such as a new subscriber being added.
2. Configuring the Webhook in Sendy
Once you have set up your trigger in Pabbly Connect, the next step is to configure the webhook in Sendy. You will need to copy the webhook URL provided by Pabbly Connect. This URL will act as a bridge for data transfer.
  • Log into your Sendy account.
  • Navigate to the campaign section and select the rule option.
  • Create a new rule and set the trigger to ‘on subscribe’.
  • Paste the copied webhook URL into the designated field.
After adding the rule, click on ‘Add’ to finalize the setup. Your Sendy account is now ready to send data to Pabbly Connect whenever a new subscriber is added.
3. Testing the Sendy and Pabbly Connect Integration
After configuring the webhook in Sendy, it’s essential to test the integration to ensure it works correctly. You can do this by adding a new subscriber through the Sendy subscribe form.
To test, follow these steps:
  • Open the subscribe form link in an incognito window.
  • Fill in the subscriber details, such as name and email.
  • Submit the form.
Once you submit the form, check your Pabbly Connect dashboard to see if the new subscriber’s data is captured successfully. This confirms that your webhook setup is functioning as intended.
4. Utilizing Subscriber Data from Sendy
With the webhook successfully set up, you can now utilize the subscriber data captured by Pabbly Connect. This data can be sent to various applications for different purposes, such as sending notifications or storing in spreadsheets.
For instance, you can:
Send a WhatsApp message to the new subscriber using WhatsApp Cloud API. Store subscriber information in Google Sheets. Notify your team via Slack or Discord.
By leveraging Pabbly Connect, you can automate these actions effortlessly, enhancing your marketing workflow.
5. Flexibility of Using Pabbly Connect for Automation
The beauty of using Pabbly Connect lies in its flexibility. You can customize your workflows to include multiple actions based on the triggers you set up. This means you can expand your automation as needed.
For example, if you wanted to add an action for unsubscribing, you could easily set that up by selecting the appropriate trigger in Pabbly Connect. This allows for comprehensive management of your email marketing efforts.
Additionally, Pabbly Connect supports various applications, making it a versatile tool for integrating different platforms seamlessly. This means you can automate processes without any coding knowledge, streamlining your business operations.
In conclusion, setting up a webhook inside Sendy using Pabbly Connect enables you to automate your email marketing processes effectively. By following the steps outlined in this tutorial, you can integrate Sendy with various applications such as WhatsApp and Google Sheets, enhancing your marketing capabilities.
