Learn how to set up a webhook inside SendX using Pabbly Connect to automate your email marketing tasks effortlessly. Follow this detailed tutorial for seamless integration.
1. Introduction to Pabbly Connect and SendX
In this tutorial, we will learn how to set up a webhook inside SendX using Pabbly Connect. This integration allows you to automate email marketing tasks efficiently. SendX is a powerful email marketing tool that helps businesses manage their email campaigns effectively.
With Pabbly Connect, you can link SendX with various applications seamlessly. This means you can automate tasks such as sending data from SendX to Google Sheets or sending WhatsApp messages. Let’s explore how to create this integration step by step.
2. Setting Up Webhook Inside SendX Using Pabbly Connect
To start, log in to your SendX account. Navigate to the automation section where you can create a new automation. The first step is to select Pabbly Connect as your integration tool. This will allow you to set up a webhook that captures data from SendX.
  • Go to the automation section in SendX.
  • Click on ‘Create Automation’ and name your automation.
  • Select ‘Webhook’ as the trigger option.
Once you have selected the webhook, you will receive a unique webhook URL from Pabbly Connect. This URL acts as a bridge for data transfer. Copy this URL to set up the connection in SendX.
3. Configuring the Webhook in SendX
After copying the webhook URL, return to your SendX account and paste this URL into the webhook settings. This step is crucial as it enables SendX to communicate with Pabbly Connect. You will need to choose the specific event that triggers the webhook.
For example, select the event ‘Contact Added via Popup Form’. This means that every time a new contact is added through your popup form, SendX will send the data to Pabbly Connect. Make sure to save these settings to activate the webhook.
4. Testing the Webhook Integration
To ensure that your webhook setup is working properly, you need to perform a test submission. Go to your website where the popup form is located. Fill in the form with test data and submit it. This action will trigger the webhook you set up in SendX.
After submitting the form, return to Pabbly Connect. You should see that the response from SendX has been captured successfully. This indicates that your webhook is functioning correctly and data is being transferred seamlessly.
5. Expanding Automation Options with Pabbly Connect
Now that your webhook is set up and tested, you can expand your automation options. With Pabbly Connect, you can integrate other applications like Google Sheets or WhatsApp to enhance your email marketing capabilities.
  • Add Google Sheets as an action to store contact details automatically.
  • Send automated WhatsApp messages to new contacts.
  • Customize your workflows based on specific triggers.
This flexibility allows you to automate various tasks and improve your marketing efficiency with Pabbly Connect.
Setting up a webhook inside SendX using Pabbly Connect allows you to automate your email marketing processes effectively. This integration simplifies data management and enhances communication with your contacts. By following the steps outlined above, you can streamline your marketing efforts and improve overall efficiency.
