Learn how to set up a webhook inside Landingi using Pabbly Connect. This detailed tutorial covers step-by-step instructions for seamless integration. Explore efficient methods for automating routine tasks with clear, concise instructions suited for both newcomers and experienced professionals.
1. Setting Up Pabbly Connect for Webhook Integration
To set up a webhook inside Landingi, you first need to access Pabbly Connect. This platform acts as a bridge between Landingi and other applications, enabling seamless data transfer.
Begin by logging into your Pabbly Connect account. Once logged in, navigate to the trigger window where you will select the Landingi application. This is crucial as it sets the groundwork for your integration.
2. Configuring the Webhook in Landingi
Now that you have set up Pabbly Connect, you need to configure the webhook in Landingi. Go to the specific page you want to integrate and click on the settings option.
  • Navigate to the Integrations tab within the settings.
  • Scroll down to the Webhook section and remove any existing webhook if necessary.
  • Paste the webhook URL from Pabbly Connect into the designated field.
Ensure that the request method is set to POST and specify the details you want to send, such as name, email, and phone number. Once done, click on Save to activate the integration.
3. Testing the Webhook Setup
After saving your settings in Landingi, return to Pabbly Connect. You will notice it is waiting for a webhook response. This indicates that the setup is ready for testing.
To test the webhook, fill out the form on your Landingi page with the required details like first name, email, and phone number. Upon submission, you should see a confirmation message indicating successful sign-up.
4. Verifying Data in Pabbly Connect
Once you have submitted the form, go back to Pabbly Connect to verify that the data has been captured. You should see the details of the submission, including the name, email, and phone number, confirming that the integration is successful.
This real-time data capture ensures that every new lead created in Landingi is instantly reflected in Pabbly Connect. This allows you to manage leads efficiently and take further actions as required.
5. Conclusion
In this tutorial, we explored how to set up a webhook inside Landingi using Pabbly Connect. By following these steps, you can easily integrate Landingi with other applications for seamless data transfer.
Utilizing Pabbly Connect not only simplifies the process but also enhances your ability to manage leads effectively. Start integrating today to streamline your workflows!
