Learn how to set up a webhook inside Cashfree using Pabbly Connect to automate payment responses to Google Sheets and other applications. Transform complex automation concepts into accessible, actionable steps that eliminate unnecessary manual work while maximizing existing application capabilities.
1. Setting Up Pabbly Connect for Cashfree Integration
To set up a webhook inside Cashfree, start by accessing Pabbly Connect. This platform enables seamless integration between Cashfree and various applications, allowing you to automate payment responses.
Once you log into Pabbly Connect, navigate to the dashboard where you can create a new workflow. Here, you will define the trigger and action applications needed for your integration.
2. Trigger Setup in Cashfree Using Pabbly Connect
In this section, you will set up the trigger in Cashfree through Pabbly Connect. Select Cashfree as your trigger application and choose the event that will initiate the workflow, such as ‘Payment via Form’.
- Choose ‘Payment via Form’ as the trigger event.
- Copy the provided webhook URL from Pabbly Connect.
- Follow the instructions to set up the webhook in your Cashfree account.
After copying the webhook URL, navigate to your Cashfree account to create a new webhook endpoint. Paste the URL into the endpoint URL field and select the appropriate webhook version before testing the connection.
3. Configuring the Webhook in Cashfree
To configure the webhook in Cashfree, go to the Developers section and select Webhooks. Click on ‘Add Webhook Endpoint’ and paste the copied URL from Pabbly Connect.
Next, select the event for which you want to receive responses. Choose ‘Success Payment’ to ensure that you capture successful transactions. After configuring, click on ‘Add Webhook’ to finalize the setup.
With the webhook successfully configured, you can now test the integration. Go back to Pabbly Connect and click on the ‘Recapture Webhook Response’ button. This will prepare the system to receive a test submission from Cashfree.
To perform a test submission, make a payment using the form you created in Cashfree. Fill in the test user details and complete the payment process. Once the payment is successful, Pabbly Connect will capture the webhook response, confirming a successful integration.
5. Expanding Your Workflow with Pabbly Connect
After confirming the successful connection, you can expand your workflow by adding more actions in Pabbly Connect. For example, you might want to send an email via Gmail or create a record in Google Sheets whenever a payment is made.
- Add Gmail as an action application to send automated emails.
- Integrate Google Sheets to log payment details automatically.
- Utilize WhatsApp Cloud API for sending order confirmations.
By leveraging Pabbly Connect, you can create a comprehensive automation system that enhances your payment processing workflow.
In this tutorial, we explored how to set up a webhook inside Cashfree using Pabbly Connect. This integration allows you to automate responses to payment events efficiently and effectively.
