Learn how to automate sending WhatsApp order confirmations for Instamojo orders using Pabbly Connect. Follow our detailed step-by-step tutorial. Learn to create powerful connections between your critical applications without requiring specialized programming knowledge or extensive technical background.
To send WhatsApp order confirmations for Instamojo orders, the first step is accessing Pabbly Connect. Start by visiting the Pabbly Connect homepage by entering Pabbly.com/connect in your browser.
Once on the homepage, you will see options to either sign in or sign up. If you are new, click on ‘Sign Up Free’ to create an account and receive 100 free tasks each month. Existing users can simply sign in to access their dashboard.
After signing in, navigate to your Pabbly Connect dashboard. Here, you will create a new workflow that connects your Instamojo account with WhatsApp. Click on the ‘Create Workflow’ button at the top right corner. using Pabbly Connect
In the workflow creation dialogue, choose the beta version for a modern experience. Name your workflow as ‘Send WhatsApp Order Confirmation for Instamojo Orders’ and select a folder for organization. You can create multiple folders to manage your workflows effectively.
- Click on the ‘Create’ button to finalize your workflow setup.
- Understand the trigger and action principles for effective automation.
Now that your workflow is created, proceed to set up the trigger that will initiate the automation process.
3. Setting Up the Trigger for Instamojo
The next step involves configuring the trigger for your workflow. Click on the ‘Add Trigger’ button and select ‘Instamojo V2’ as your trigger application. Choose the event ‘New Sale’ to capture new payments.
After selecting the event, click on ‘Connect’ to generate a webhook URL. This URL is crucial for linking your Instamojo account with Pabbly Connect. Copy the webhook URL provided and head over to your Instamojo account.
- Go to ‘Smart Pages’ in your Instamojo account and edit the payment page.
- Enable the webhook option and paste the copied URL.
- Select ‘Successful Payment’ as the event to trigger the webhook.
Click on ‘Save and Update’ to complete the setup. Your Instamojo account is now connected to Pabbly Connect and ready to send data when a new payment occurs.
4. Testing the Setup with a Test Payment
After configuring the trigger, it’s essential to test the setup. To do this, make a test payment through your Instamojo account. Copy the payment page link and paste it into a new browser tab.
Fill in the required details, including a dummy name, email, and phone number, and proceed to make the payment. Once the payment is successful, return to Pabbly Connect and wait for the webhook response.
Ensure you receive a successful response with the customer details. This response confirms that the trigger is working correctly.
With the successful response, your trigger is now fully operational, and you can proceed to set up the action step to send WhatsApp messages.
5. Setting Up the Action to Send WhatsApp Messages
Now, it’s time to configure the action step that sends the WhatsApp confirmation message. Click on the ‘Add Action’ button and select ‘WhatsApp Cloud API’ as the action application. Choose the event ‘Send Template Message’ to send your customized message. using Pabbly Connect
Click on ‘Connect’ and select ‘Add a New Connection’. Here, enter your WhatsApp Cloud API token, phone number ID, and WhatsApp business account ID. You can obtain these details from your Meta account where you set up the WhatsApp Cloud API.
Map the receiver’s phone number from the previous step’s response. Select the template ID you created for order confirmations. Fill in the required fields and click on ‘Save and Send Request’.
Once you receive a successful response, check your WhatsApp for the confirmation message. This indicates that your automation setup is complete, allowing you to send personalized order confirmations automatically.
In this tutorial, we explored how to use Pabbly Connect to automate sending WhatsApp order confirmations for Instamojo orders. By following these steps, you can easily set up an efficient workflow that enhances customer communication and streamlines your order processing.
Utilizing Pabbly Connect not only saves time but also ensures that your customers receive timely updates about their orders, improving overall satisfaction.
