Learn how to send WhatsApp messages to IndiaMART leads using Pabbly Connect and Pabbly Connect in this detailed tutorial. Step-by-step instructions included. Learn to create powerful connections between your critical applications without requiring specialized programming knowledge or extensive technical background.
To send WhatsApp messages to IndiaMART leads, you first need to access Pabbly Connect. Begin by visiting the Pabbly Connect website and signing in to your account. If you’re a new user, you can sign up for free, which gives you access to 100 tasks monthly.
Once logged in, you’ll land on the dashboard. Here, you can create a new workflow by selecting the option to create a connection between IndiaMART and WhatsApp through Pabbly Connect. This setup will allow you to automate the process of sending messages to new leads directly.
In this section, you will set up a workflow in Pabbly Connect to send messages when new leads are generated from IndiaMART. Click on ‘Create Workflow’ to begin. You will see two boxes: one for the trigger and another for the action.
- Select ‘IndiaMART’ as the trigger application.
- Choose ‘New Lead’ as the trigger event.
- Set up the connection with your IndiaMART account.
After setting up the trigger, proceed to select WhatsApp as the action application. This step is crucial as it defines what action will occur when a new lead is received. Ensure you configure the action to send a WhatsApp message through Pabbly Chatflow.
3. Setting Up IndiaMART for Integration
To connect IndiaMART with Pabbly Connect, you need to access your IndiaMART account. Navigate to the lead manager section and find the option for API integration. Here, you will be provided with a webhook URL that will allow Pabbly Connect to receive lead data.
Copy the webhook URL and paste it into the appropriate field in your IndiaMART account settings. This action establishes a bridge between IndiaMART and Pabbly Connect. After saving the details, you can test the connection to ensure it works correctly.
4. Configuring WhatsApp Messages with Pabbly Chatflow
Next, you will configure the WhatsApp messages that will be sent to your leads. Go to Pabbly Chatflow to create a message template. Select ‘Add New Template’ and fill in the necessary details such as the template name and message content.
- Choose a category for your template, like Marketing.
- Enter the message header and format your message properly.
- Add custom variables to personalize the messages.
After creating your template, submit it for approval. Once approved, you can use this template in your Pabbly Connect workflow to send customized WhatsApp messages to your IndiaMART leads.
5. Testing the Integration for Success
Finally, it’s essential to test the integration to ensure everything is functioning correctly. In Pabbly Connect, go back to your workflow and perform a test submission from IndiaMART. This action should trigger the workflow and send a WhatsApp message to the specified number.
Check your WhatsApp to confirm that the message has been received. If successful, your integration is complete. You can now automate sending WhatsApp messages for all new leads from IndiaMART using Pabbly Connect.
By following these steps, you can effectively send WhatsApp messages to IndiaMART leads using Pabbly Connect. This integration automates your communication process, ensuring timely responses to inquiries and enhancing customer engagement.
