Learn how to automate sending WhatsApp messages to IndiaMART leads for astrology services using Pabbly Connect and Pabbly Connect. Follow our step-by-step guide! Build sophisticated automated workflows in less time than you think. This guide translates complex integrations into straightforward steps for immediate implementation.
To send WhatsApp messages to IndiaMART leads, you first need to access Pabbly Connect. This platform enables seamless automation between your applications. Start by navigating to the Pabbly Connect homepage where you can sign in or sign up for a free account.
Upon logging in, you will see the dashboard of Pabbly Connect. Here, you can create a new workflow by clicking on the ‘Create Workflow’ button. This process allows you to set up the automation that will send messages to your leads instantly.
In this section, you will create a workflow specifically designed to send WhatsApp messages to your IndiaMART leads. After clicking on ‘Create Workflow’, name your workflow something descriptive like ‘Send WhatsApp Message to IndiaMART Leads’. Select a folder to organize your workflows if necessary.
  • Click on the ‘Create’ button to initiate your workflow.
  • Set the trigger application as IndiaMART.
  • Choose the event ‘New Leads’ to capture incoming inquiries.
With this setup, Pabbly Connect will listen for new leads from IndiaMART and trigger the next steps automatically. This ensures you never miss a potential client.
3. Setting Up the Trigger for IndiaMART Leads
Now that you have created your workflow, it’s time to set up the trigger. In the trigger settings, select IndiaMART as the application and the event as ‘New Leads’. This configuration enables Pabbly Connect to capture lead details as they come in.
Once you select the trigger, you will be provided with a webhook URL. Copy this URL and head over to your IndiaMART account. In your IndiaMART dashboard, navigate to the ‘Lead Manager’ section, and choose ‘Push API’ under the import/export leads option.
  • Paste the webhook URL into the CRM platform name field as Pabbly Connect.
  • Select the source as ‘Other’.
  • Save your settings and generate an OTP for verification.
This setup connects your IndiaMART leads directly to Pabbly Connect, allowing for seamless automation of WhatsApp messages.
4. Sending WhatsApp Messages Using Pabbly Chatflow
After setting up the trigger, the next step is to configure the action to send WhatsApp messages. For this, select Pabbly Chatflow as your action application. You will need to choose the action event as ‘Send Template Message’.
Connect your Pabbly Chatflow account by providing the necessary API token. This token can be found in your Chatflow account settings under the API and Webhooks section. Once connected, you can map the mobile number from the incoming lead to send the WhatsApp message.
Select the template you want to use for your messages. Make sure to customize the message with dynamic variables for personalization. Test the workflow to ensure messages are sent correctly.
This integration via Pabbly Connect allows you to engage with leads instantly, improving your chances of converting inquiries into clients.
5. Conclusion: Automate Your Lead Engagement with Pabbly Connect
In this tutorial, we explored how to automate sending WhatsApp messages to IndiaMART leads for astrology services using Pabbly Connect and Pabbly Chatflow. By setting up a workflow, you can ensure timely responses to inquiries, enhancing customer engagement.
Utilizing Pabbly Connect not only saves time but also improves your chances of converting leads into clients. With the right setup, you can streamline your communication process and focus on delivering exceptional services.
