Learn how to automate sending WhatsApp messages to Facebook leads using Pabbly Connect and Pabbly Connect with this step-by-step tutorial. Learn to create powerful connections between your critical applications without requiring specialized programming knowledge or extensive technical background.
1. Access Pabbly Connect for Automation
To start sending WhatsApp messages to Facebook leads, the first step is to access Pabbly Connect. Open your browser and type in Pabbly.com/connect to reach the landing page.
On this page, you will see two options: ‘Sign In’ and ‘Sign Up for Free’. If you are a new user, click on ‘Sign Up for Free’ to create an account, which takes only a couple of minutes. Existing users can simply log in.
After signing in, you will be directed to the dashboard of Pabbly Connect. Here, you can manage your workflows. To create a new workflow, click on the ‘Create Workflow’ button.
A dialog box will prompt you to name your workflow. Enter a name like ‘Send WhatsApp Messages to Facebook Leads’ and select a folder to save it. Once done, click on ‘Create’ to establish the workflow.
- Click on ‘Create Workflow’.
- Select the appropriate folder for organization.
This will take you to a blank workflow screen where you can set up your trigger and action steps. Remember, the trigger is what starts the automation, and the action is the response that follows.
3. Set Up Trigger with Facebook Lead Ads
Now, we will configure the trigger in Pabbly Connect. Select Facebook Lead Ads as your trigger application. Choose the trigger event as ‘New Lead Instant’ to capture leads immediately when they come in.
Next, click on ‘Connect’ to establish a connection between Pabbly Connect and your Facebook account. If prompted, log in to your Facebook account to authorize the connection.
- Select Facebook Lead Ads as the trigger application.
- Choose the ‘New Lead Instant’ event.
- Connect your Facebook account when prompted.
Once the connection is successful, select the Facebook page where your lead ads are running. Choose the lead generation form that captures your leads. After this, click on ‘Save and Send Test Request’ to test the integration.
4. Send WhatsApp Message Using Pabbly Chatflow
With the trigger set up, the next step is to send a WhatsApp message using Pabbly Chatflow. Select Pabbly Chatflow as your action application and choose the action event ‘Send Template Message’. This will allow you to send customized WhatsApp messages.
To establish this connection, click on ‘Connect’ and enter your API token from your Pabbly Chatflow account. Once connected, you will need to fill in the recipient’s mobile number and select the appropriate message template.
Select the action application as Pabbly Chatflow. Choose ‘Send Template Message’ as the action event. Enter the API token to establish the connection.
Map the phone number and other details dynamically from the previous step to ensure each WhatsApp message is personalized for the lead. Once all fields are filled, click on ‘Save and Send Test Request’ to verify if the message is sent successfully.
5. Conclusion
In conclusion, using Pabbly Connect and Pabbly Chatflow allows you to automate the process of sending WhatsApp messages to Facebook leads effortlessly. This integration enhances lead engagement and ensures timely communication.
By following this step-by-step tutorial, you can easily set up the automation for your business, ensuring that every new lead receives a personalized WhatsApp message without any manual intervention. Start using Pabbly Connect today to streamline your lead communication process!
