Learn how to integrate WhatsApp with Facebook Leads for your renewable energy business using Pabbly Connect. Follow our step-by-step tutorial. Navigate the automation landscape confidently with clear, structured guidance suitable for professionals regardless of prior technical experience.
To begin sending WhatsApp messages to Facebook leads for your renewable energy business, you need to access Pabbly Connect. This platform will help you automate the process of sending messages whenever a new lead is generated.
Start by visiting the Pabbly Connect website. If you are a new user, click on the ‘Sign Up Free’ button. Existing users can simply click on ‘Sign In’. Once logged in, you will reach the dashboard where you can manage your workflows.
In this section, we will create a new workflow in Pabbly Connect to connect Facebook Lead Ads and WhatsApp Cloud API. Click on ‘Create Workflow’ and name it ‘Send WhatsApp Message to Facebook Leads for Renewable Energy Business’.
- Select the folder for your workflow.
- Choose your trigger application, which is Facebook Lead Ads.
- Set the trigger event to ‘New Lead Instant’.
After setting up the trigger, connect your Facebook Lead Ads account to Pabbly Connect. Ensure you select the correct Facebook page and lead generation form to capture the leads accurately.
3. Testing the Trigger with Sample Submission
Once your trigger is set, it’s essential to test it to ensure everything is working correctly. In Pabbly Connect, click on ‘Save and Send Test Request’. You will see a message indicating that it is waiting for a webhook response.
To generate a test lead, navigate to the Meta for Developers page and use the Lead Ads Testing Tool. Make sure to delete any previous leads to create a new one. Fill out the form with dummy details and submit it to confirm that the lead data is captured correctly.
4. Setting Up WhatsApp Cloud API in Pabbly Connect
The next step is to set up the WhatsApp Cloud API as the action application in Pabbly Connect. Select ‘Send Template Message’ as your action event. This will allow you to send a predefined message whenever a new lead is captured.
- Connect your WhatsApp Cloud API account by entering your API token and phone number ID.
- Select the template message you wish to send to your leads.
- Map the recipient’s mobile number and ensure the body field is filled.
After completing these steps, click on ‘Save and Send Test Request’ to verify that the WhatsApp message is sent successfully to the lead captured from Facebook.
5. Finalizing Your Integration Workflow
After testing both the trigger and action, you can finalize your workflow in Pabbly Connect. Ensure that all connections are properly set up and functioning. You should see the message status as accepted after sending the test request.
This means you have successfully integrated Facebook Lead Ads with WhatsApp Cloud API through Pabbly Connect. Any new leads generated from your Facebook ads will automatically receive a WhatsApp message, streamlining your communication process.
In this tutorial, we demonstrated how to use Pabbly Connect to send WhatsApp messages to Facebook leads for your renewable energy business. By following these steps, you can automate your lead communication effectively and enhance your marketing efforts.
