Learn how to send automated WhatsApp messages to Facebook leads in the mining industry using Pabbly Connect. Follow our step-by-step tutorial for seamless integration. Explore systematic approaches to creating efficient automation solutions that convert technical concepts into practical, implementable instructions.
To send WhatsApp messages to Facebook leads, start by accessing Pabbly Connect. This platform allows you to automate the integration between various applications seamlessly.
Visit the Pabbly Connect landing page where you can either sign in or sign up. New users can click on ‘Sign Up Free’ to get 100 free tasks monthly, while existing users should click ‘Sign In’. Once logged in, you can access all Pabbly applications to set up your automation.
After logging into Pabbly Connect, you will see the dashboard. Click on the ‘Create Workflow’ button to initiate a new workflow for sending WhatsApp messages.
- Name your workflow, for example, ‘Coalfield Minds Facebook Leads to WhatsApp Message’.
- Select a folder for your workflow for better organization.
This workflow will consist of a trigger and an action. The trigger will be Facebook Lead Ads, and the action will be sending a message via WhatsApp Cloud API.
To set up your trigger in Pabbly Connect, select Facebook Lead Ads as your trigger application. The trigger event should be set to ‘New Lead Instant’, which captures new leads automatically.
Click on ‘Connect’ to establish a connection with Facebook. If you haven’t connected your Facebook account yet, choose ‘Add New Connection’. Select your Facebook account and the specific page, such as ‘Coalfield Minds’. Next, select your lead form (e.g., ‘Metals and Mining Form’) to ensure only relevant leads are captured.
4. Configuring the Action in Pabbly Connect
Now it’s time to configure the action step in Pabbly Connect. Choose WhatsApp Cloud API as your action application and set the action event to ‘Send Template Message’.
Again, click on ‘Add New Connection’ to link your WhatsApp Cloud API account. You will need to input the temporary access token, phone number ID, and WhatsApp Business Account ID from your WhatsApp Cloud API setup in Meta for Developers.
- Select the template you want to use for sending messages.
- Map the recipient’s mobile number and any variables needed in the message.
- Save and send a test request to ensure everything is set up correctly.
Once the test request is successful, you will see a confirmation that the message was accepted, indicating that your automation is working.
5. Testing and Verifying Your Automation
After setting everything up in Pabbly Connect, it’s essential to test the automation. Return to the lead testing tool in Meta for Developers and delete any previous test leads to create a new one.
Submit a new lead with the required information, including your actual phone number. Once submitted, check your WhatsApp for the automated message. You should receive a personalized message confirming the lead’s inquiry.
This successful test confirms that your integration between Facebook Lead Ads and WhatsApp via Pabbly Connect is working perfectly, allowing you to communicate with potential clients efficiently.
In this tutorial, we explored how to send WhatsApp messages to Facebook leads in the mining industry using Pabbly Connect. By automating this process, you can enhance communication with leads and streamline your business operations effectively.
