Learn how to automate WhatsApp messages for Thrivecart purchases using Pabbly Connect and Pabbly Connect. Step-by-step tutorial included. Implement the precise methodologies leading organizations use to automate repetitive tasks, illustrated with practical examples designed for immediate application.
1. Accessing Pabbly Connect for Thrivecart and WhatsApp Integration
To start sending WhatsApp messages upon Thrivecart purchases, you need to access Pabbly Connect. This platform enables seamless automation between your Thrivecart account and WhatsApp through Pabbly Chatflow.
Begin by signing into your Pabbly Connect account. If you are a new user, you can sign up for free and receive 100 tasks each month. After logging in, locate the ‘Access Now’ button under Pabbly Connect to enter the dashboard where you can create workflows.
Once in the Pabbly Connect dashboard, you need to create a workflow to automate the message sending process. Click on the ‘Create Workflow’ button located at the top right corner. A dialog box will appear, prompting you to name your workflow.
- Name the workflow: ‘Send WhatsApp Message on Thrivecart Purchase’.
- Select a folder to save this workflow.
After entering the workflow name and selecting a folder, click the ‘Create’ button. You will see two sections: Trigger and Action. The Trigger is what starts the workflow, while the Action is what happens as a result.
3. Setting Up the Trigger with Thrivecart
For the Trigger application, select ‘Thrivecart’ since you want to capture purchases made by students. Choose the event as ‘Product Purchase’ to ensure that the workflow activates when a specific product is purchased.
Next, connect your Thrivecart account by clicking the ‘Connect’ button. You will need to create an API key in your Thrivecart account for this connection. To do this, navigate to the API settings in your Thrivecart account, create a new API key, and copy it into Pabbly Connect to finalize the connection.
4. Sending WhatsApp Messages Using Pabbly Chatflow
After successfully setting up the Trigger, it’s time to configure the Action. Select ‘Pabbly Chatflow’ as the action application and choose the event ‘Send Custom Request’. This allows you to send WhatsApp messages based on the purchase information captured by Thrivecart. using Pabbly Connect
- Connect your Pabbly Chatflow account using the API token from your Chatflow settings.
- Map the customer’s phone number and order details to personalize the WhatsApp message.
Make sure to create a message template in Pabbly Chatflow that includes dynamic fields like the customer’s name and order details. This ensures that each message is tailored to the individual customer, enhancing their experience.
5. Testing the Integration
To ensure everything is working correctly, perform a test purchase in Thrivecart. This will trigger the workflow in Pabbly Connect and send a WhatsApp message via Pabbly Chatflow. Check your WhatsApp inbox to confirm receipt of the message.
If the message appears as intended, your integration is successful! This automation saves you time and ensures your customers receive immediate confirmation of their purchases, enhancing their overall experience with your services.
In this tutorial, we explored how to use Pabbly Connect and Pabbly Chatflow to automate WhatsApp messages for Thrivecart purchases. By following these steps, you can streamline your communication with customers and improve their experience.
