Learn how to automate WhatsApp messages for successful payments in Thrivecart using Pabbly Connect. Step-by-step tutorial inside! Implement the precise methodologies leading organizations use to automate repetitive tasks, illustrated with practical examples designed for immediate application.
1. Setting Up Pabbly Connect for Thrivecart Integration
To begin the integration process, you will first need to access Pabbly Connect. This platform serves as the automation solution that connects Thrivecart with WhatsApp. After signing up or logging in, navigate to the app section and select Pabbly Connect to create a new workflow.
Once in Pabbly Connect, you will be prompted to create a workflow. Name it appropriately, such as ‘Thrivecart to WhatsApp Integration’. This will help you identify the automation later. After naming, click on the ‘Create’ button to move forward.
2. Connecting Thrivecart to Pabbly Connect
The next step involves connecting Thrivecart to Pabbly Connect. You will need to retrieve your API token from Thrivecart. To do this, go to your Thrivecart account, click on ‘Settings’, and then navigate to ‘API & Webhooks’. Here, you can generate a new API key specifically for this integration.
- Log into Thrivecart and navigate to Settings.
- Go to API & Webhooks and create a new API key.
- Copy the API key and paste it into Pabbly Connect.
After pasting the API token into Pabbly Connect, select the trigger event as ‘Product Purchase’. This will ensure that every time a payment is made, the workflow is activated. Click on ‘Connect’ to finalize this setup.
3. Collecting Payment Data from Thrivecart
Once Thrivecart is connected to Pabbly Connect, it’s time to collect payment data. This is done by making a test payment through Thrivecart. Fill out the checkout form with a dummy customer, such as John Mosby, and complete the order.
After the payment is processed, return to Pabbly Connect and click on ‘Test Request’. This action will pull the payment data from Thrivecart, which includes customer details like name, email, and phone number. Ensure that this data is accurately reflected in Pabbly Connect.
4. Enrolling User in Thinkific via Pabbly Connect
Now that you have the payment data, the next step is to enroll the user in Thinkific. In your Pabbly Connect workflow, add a new action step and select Thinkific as the application. Choose the action event as ‘Create User’.
Map the fields from the payment data you collected, such as first name, last name, and email address. After filling in these details, click on ‘Save and Send Test Request’. This will create a new user in Thinkific, confirming that John Mosby is now enrolled in your course.
5. Sending WhatsApp Confirmation Message
The final step is to send a confirmation message via WhatsApp. For this, you will use Wati, which integrates with Pabbly Connect. Add a new action step and select Wati, then choose the action event as ‘Send Template Message’.
- Enter the WhatsApp number without the plus sign and include the country code.
- Select the message template you created in Wati.
- Fill in the custom parameters such as name and course link.
Click on ‘Save and Send Test Request’ to dispatch the message. The system will confirm that the message has been sent to John Mosby, providing him with all necessary information regarding his enrollment.
In this tutorial, we explored how to automate the process of sending WhatsApp messages upon successful payment using Pabbly Connect. By integrating Thrivecart and Thinkific, you can streamline your workflow and enhance customer communication effectively.
