Learn how to automate WhatsApp messages for ModWebs orders using Pabbly Connect. This step-by-step tutorial covers everything you need to know. Develop expertise in application integration and learn how to design streamlined automation workflows using proven, simplified approaches.
To automate WhatsApp messages for ModWebs orders, you first need to access Pabbly Connect. Start by visiting Pabbly.com/connect and sign up for a free account if you don’t have one. If you already have an account, just sign in to access the dashboard.
Once logged in, navigate to the dashboard and click on ‘Create Workflow’. Name your workflow, for example, ‘ModWebs to WhatsApp’, and click on ‘Create’. This will initiate the workflow setup where you can define the trigger and action for your automation.
2. Setting Up the Trigger for New Orders
In this step, you will set up the trigger in Pabbly Connect that detects new orders from ModWebs. In the trigger window, search for ‘ModWebs’ and select it. Then, choose the trigger event as ‘New Order’ from the dropdown menu. This sets up the automation to react when a new order is placed.
- Select ‘ModWebs’ as the app.
- Choose ‘New Order’ as the trigger event.
- Copy the generated webhook URL.
After copying the webhook URL, go to your ModWebs account. In the website settings, navigate to ‘Applications’ and click on ‘Add Application’. Select ‘Connect Webhook’ and paste the copied URL into the destination URL field. Select ‘New Order’ as the event and click ‘Save’. Your ModWebs account is now connected to Pabbly Connect.
3. Placing a Test Order to Capture Data
Now that you have set up the trigger, it’s time to place a test order to capture the order details in Pabbly Connect. Open your ModWebs store and proceed to checkout. Enter the details of a dummy customer, such as name, email, address, and mobile number, then complete the order.
Once the order is placed, return to Pabbly Connect to see the captured response. You should see all the details of the new order, including the customer’s name, email, address, and the product ordered. This data will be used to send a WhatsApp confirmation message.
With the order details captured, you can now set up the action to send a WhatsApp message. In the action window of Pabbly Connect, search for ‘WhatsApp Cloud API’ and select it. Choose the action event ‘Send Template Message’ and click on ‘Connect’.
- Connect using your WhatsApp Cloud API credentials.
- Select the template you wish to use for the message.
- Map the customer’s WhatsApp number and other dynamic fields.
Ensure that you have a pre-approved template message in your WhatsApp Cloud API account. For example, use a template named ‘Order Confirmed’ that includes dynamic fields for the customer’s name and product. After filling in all required fields, send a test request to confirm that the WhatsApp message is sent successfully.
5. Conclusion: Automating Your ModWebs Orders with Pabbly Connect
In this tutorial, you learned how to automate WhatsApp messages for ModWebs orders using Pabbly Connect. By setting up a trigger for new orders and an action to send WhatsApp messages, you can enhance customer communication seamlessly.
Now, whenever a new order is placed, a confirmation message will be sent automatically, ensuring that your customers are kept informed. This integration not only saves time but also improves customer satisfaction by providing timely updates.
