Learn how to integrate TradingView alerts with Telegram using Pabbly Connect. This step-by-step guide covers all necessary actions to automate alert messages. Explore efficient methods for automating routine tasks with clear, concise instructions suited for both newcomers and experienced professionals.
1. Setting Up Pabbly Connect for TradingView Alerts
To send TradingView alerts on Telegram, you first need to set up Pabbly Connect. Start by signing up for a free account at Pabbly Connect’s website. Once you’re logged in, navigate to the dashboard and click on ‘Create Workflow’ to initiate the automation process.
When prompted, name your workflow, for example, ‘TradingView to Telegram’. This name helps you identify the workflow later. After naming, click on ‘Create’ to open the workflow interface, which consists of trigger and action windows that facilitate the integration process.
2. Configuring the Trigger Event in Pabbly Connect
In the trigger window of Pabbly Connect, search for and select ‘TradingView’. Choose the trigger event as ‘New Alert’ from the dropdown menu. This step is crucial as it allows Pabbly Connect to listen for new alerts generated in your TradingView account.
- Select TradingView as the app
- Choose ‘New Alert’ as the trigger event
- Copy the provided webhook URL
Next, paste this webhook URL into your TradingView alert settings. This connection allows TradingView to send alert messages directly to Pabbly Connect, enabling further actions.
3. Creating an Alert in TradingView
Now, go to your TradingView account and create a new alert. For example, set an alert for the Nifty index. Click on the ‘Create Alert’ button and specify the conditions under which you want to receive alerts, such as when the index crosses a specific value. using Pabbly Connect
- Set the alert condition (e.g., Nifty crossing 18349 points)
- Select ‘Webhook URL’ and paste the URL from Pabbly Connect
- Customize the alert message with placeholders for details like volume and price
Ensure you click ‘Create’ to activate the alert. This setup allows TradingView to send the alert to Pabbly Connect whenever the specified condition is met.
4. Setting Up Telegram Integration in Pabbly Connect
After configuring the trigger, it’s time to set up the action in Pabbly Connect. In the action window, search for ‘Telegram’ and select ‘Telegram Bot’. Choose the action event as ‘Send Text Message’. This step is essential for sending the alert messages to your Telegram channel or group.
To connect your Telegram bot with Pabbly Connect, you need to create a bot using the BotFather on Telegram. After creating the bot, copy the API token provided and paste it back into Pabbly Connect to establish the connection.
With the bot connected, you will need to specify the chat ID of your Telegram group or channel where the alert messages will be sent. You can find the chat ID by accessing the group or channel and copying it from the URL. using Pabbly Connect
In Pabbly Connect, map the message field with the alert response received from TradingView. This mapping ensures that every time an alert is triggered, the message is sent to your Telegram channel with relevant details.
Finally, click on ‘Save’ and then ‘Test Request’ to check if everything is working correctly. If successful, you will see the alert message appear in your Telegram channel, confirming that the integration is functioning as intended.
By following these steps, you can effectively send TradingView alerts to your Telegram channel using Pabbly Connect. This integration automates the process, ensuring timely updates for your community. Start using this powerful automation tool to enhance your trading experience.
