Learn how to automate sending TradingView alerts to your Discord channel using Pabbly Connect. A step-by-step guide to streamline your trading alerts. Revolutionize your productivity approach with just a few strategic clicks. Uncover professional methods for connecting applications and creating workflows that reclaim hours of your week.
To send TradingView alerts on Discord, you need to access Pabbly Connect. Start by opening your browser and navigating to the Pabbly Connect website. If you’re new, click on ‘Sign up free’ to create an account. Existing users can simply sign in.
Once logged in, you will see the ‘All Apps’ page. Click on ‘Access Now’ under Pabbly Connect to reach the dashboard. Here, you will create a new workflow for the integration between TradingView and Discord.
In the Pabbly Connect dashboard, click on the ‘Create Workflow’ button. Name your workflow something descriptive, like ‘TradingView to Discord Alerts’. After naming, select the folder where you want this workflow stored and click on ‘Create’. using Pabbly Connect
- Click ‘Create Workflow’ on the dashboard.
- Name your workflow (e.g., TradingView to Discord Alerts).
- Select a folder for organization.
After creating the workflow, you will see two sections: the trigger window and the action window. The trigger is where you define what starts the automation, which in this case is a new alert from TradingView.
3. Setting Up TradingView as the Trigger in Pabbly Connect
In the trigger window, select ‘TradingView’ as the app. From the trigger event dropdown, choose ‘New Alert’. This will set Pabbly Connect to listen for new alerts from your TradingView account. After this, you will receive a webhook URL. using Pabbly Connect
Copy this webhook URL and head to your TradingView account. Create a new alert by selecting the desired stock or index, such as Nifty50. In the alert creation window, set the alert condition and paste the webhook URL in the notification section.
- Select ‘TradingView’ as the app in the trigger window.
- Choose ‘New Alert’ as the trigger event.
- Copy the provided webhook URL into your TradingView alert settings.
Once the alert is created, you will see incoming alerts in Pabbly Connect whenever the conditions are met. This completes the first part of your automation setup.
4. Sending Alerts to Discord Channel via Pabbly Connect
Now that you’ve set up TradingView to send alerts to Pabbly Connect, the next step is to send these alerts to your Discord channel. In the action window, select ‘Discord’ as the app. Then, choose ‘Send Channel Message’ as the action event. using Pabbly Connect
To connect Discord, you will need to generate a new webhook URL in your Discord server settings. Navigate to your server settings, create a new webhook, and copy the URL. Paste this URL into Pabbly Connect in the Discord action step.
Select ‘Discord’ as the app in the action window. Choose ‘Send Channel Message’ as the action event. Paste the copied webhook URL from Discord into Pabbly Connect.
Map the alert message from TradingView to the message field in Discord. After setting up the message, click ‘Save and Send Test Request’ to ensure everything is working correctly. You should see the alert message posted in your designated Discord channel.
After completing the setup in Pabbly Connect, it’s crucial to test the integration. Trigger an alert in TradingView to confirm that the alert message is successfully sent to your Discord channel. You should see the message reflecting the conditions you set in TradingView.
Monitor the alerts for a while to ensure consistency. Each time the alert conditions are met in TradingView, the messages should automatically appear in your Discord channel without any manual intervention. This automation will streamline your trading alerts effectively.
With Pabbly Connect, you can connect various apps and automate numerous workflows, enhancing your productivity. This integration not only saves time but also ensures your community stays updated with real-time alerts.
Using Pabbly Connect, you can easily automate sending TradingView alerts to your Discord channel. This integration allows for real-time updates, ensuring your community is always informed about important trading signals. Implement this setup to enhance your trading experience and communication.
