Learn how to automate Telegram messages for new Instamojo payments using Pabbly Connect with this step-by-step tutorial. This comprehensive guide reveals exactly how to connect your applications and automate repetitive tasks — accessible for professionals of all technical backgrounds.
1. Setting Up Pabbly Connect for Instamojo and Telegram Integration
To send Telegram messages for new Instamojo payments, you first need to set up Pabbly Connect. Start by visiting the Pabbly Connect website and signing up for a free account. Once you log in, you’ll be directed to the dashboard where you can create your automation workflow.
Click on the ‘Create Workflow’ button to initiate the process. Name your workflow something relevant, like ‘Instamojo to Telegram Automation’, and click on ‘Create’. This sets the foundation for your integration, where Pabbly Connect will manage the communication between Instamojo and Telegram.
2. Selecting Trigger Event in Pabbly Connect
In your newly created workflow, you need to set the trigger event. Click on the trigger application field and select ‘Instamojo’. Choose the trigger event as ‘New Sale’. This event will initiate the workflow every time a new payment is made through Instamojo.
- Select ‘Instamojo’ as the trigger application.
- Choose ‘New Sale’ as the trigger event.
- Copy the generated webhook URL provided by Pabbly Connect.
Next, you will integrate this webhook URL with your Instamojo account. This step is crucial as it allows Pabbly Connect to receive payment notifications from Instamojo, which will be used to send Telegram messages.
3. Configuring Instamojo for Webhook Integration
Log into your Instamojo account and navigate to the products section. Select the product for which you want to receive payment notifications. Under the advanced options, locate the webhook URL field and paste the URL copied from Pabbly Connect.
After pasting the URL, make sure to save the changes. This action establishes a connection between Instamojo and Pabbly Connect, allowing the latter to capture payment data every time a transaction occurs. You will need to perform a test payment to ensure everything is set up correctly.
4. Performing a Test Payment to Capture Data
To test the integration, go back to your Instamojo product page and click on the ‘Buy Now’ button. Fill in the necessary details as a demo customer and complete the payment process. This step is essential as it allows Pabbly Connect to receive the payment data for the first time.
Once the payment is completed, return to your Pabbly Connect dashboard, where you should see the payment data captured in the response section. This data will include the buyer’s name, phone number, email, and payment amount, which will be used for the Telegram message.
5. Setting Up Telegram Action in Pabbly Connect
Now that you have the payment data, it’s time to set up the action that will send a message via Telegram. In the action step of your workflow, select ‘Telegram Bot’ as the action application, and choose ‘Send Text Message’ as the action event. using Pabbly Connect
- Connect your Telegram bot by providing the bot token.
- Add the chat ID of the group where you want to send messages.
- Compose your message using the mapped data from the payment response.
After setting up the message, click on ‘Save and Send Test Request’ to verify if the message is sent successfully to your Telegram group. If the setup is correct, you will receive a notification in your Telegram group confirming the payment.
In this tutorial, we demonstrated how to use Pabbly Connect to automate Telegram messages for new Instamojo payments. By following these steps, you can ensure that you receive instant notifications for every payment, allowing for prompt actions. This integration not only saves time but also enhances your operational efficiency.
