Learn how to integrate Tally Forms with Discord using Pabbly Connect for automated notifications on form submissions. Follow our step-by-step guide. Follow this definitive guide to creating powerful automated workflows with straightforward, efficiency-focused solutions that save valuable time.
To send Tally Forms submissions to a Discord channel, the first step is to access Pabbly Connect. This powerful automation tool allows users to integrate various applications seamlessly. Start by searching for Pabbly Connect in your browser and navigate to the official landing page.
Once on the landing page, you will see options to sign in or sign up. If you are a new user, click on ‘Sign up for free’ to create an account. Existing users can click on ‘Sign In’ to access their dashboard. After logging in, select the option to access Pabbly Connect to begin creating your workflow.
After accessing Pabbly Connect, the next step is to create a workflow. Click on the ‘Create Workflow’ button, where you will be prompted to name your workflow and choose a folder for organization. Name your workflow something descriptive, like ‘Send Tally Forms Submissions to Discord’ and select the appropriate folder.
- You will be taken to the workflow window where you can set up your trigger and action.
In this window, you will define the trigger application. Select Tally Forms as your trigger application and set the trigger event to ‘New Response’. This means that every time a new form submission is received, the workflow will be activated, allowing you to send notifications to Discord.
3. Setting Up Tally Forms with Pabbly Connect
To connect Tally Forms with Pabbly Connect, you need to copy the generated webhook URL. This URL will be used to link Tally Forms to your workflow. After copying the URL, log in to your Tally account and navigate to the form you want to integrate.
In Tally, go to the ‘Integrations’ tab, select ‘Webhooks’, and paste the copied webhook URL into the provided field. Click on ‘Connect’ to finalize the integration. This step establishes a connection between Tally Forms and Pabbly Connect, allowing form submissions to trigger actions in Discord.
4. Configuring Discord to Receive Notifications
Once Tally Forms is integrated with Pabbly Connect, the next step is to set up Discord. In your workflow, add an action step and select Discord as the action application. Choose the action event ‘Send Channel Message (Markdown)’ to send formatted messages to your Discord channel.
- Click on ‘Connect’ to link your Discord account.
- Follow the prompts to generate a new webhook URL from your Discord server settings.
Paste the Discord webhook URL into Pabbly Connect. Then, customize the message format by mapping the response fields from Tally Forms to the Discord message. This allows for dynamic messages that include the name, email, and course details from each submission.
5. Testing the Integration
After setting up everything, it’s time to test the integration. Submit a test response through your Tally form. Upon submission, Pabbly Connect should capture the response and send a notification to the specified Discord channel. Check your Discord to confirm that the message appears as expected.
If the message is received, congratulations! Your integration between Tally Forms and Discord via Pabbly Connect is successful. This automation will now run in the background, ensuring your team is notified of new submissions without any manual effort.
In this tutorial, we explored how to send Tally Forms submissions to Discord using Pabbly Connect. By following the steps outlined, you can automate notifications for your team, ensuring they stay updated on potential client inquiries efficiently.
