Learn how to integrate Tally Forms with Discord using Pabbly Connect to automate notifications for form submissions. Step-by-step guide included. Discover hidden automation capabilities within your existing tools. This guide shows you how to connect your essential applications and permanently eliminate redundant manual processes.
To integrate Tally Forms with Discord, you need to access Pabbly Connect. This powerful automation tool allows you to connect various applications seamlessly. Start by visiting the Pabbly Connect website and either sign in if you are an existing user or sign up for free if you are new.
Once logged in, you will find an option to create a new workflow. Click on the ‘Create Workflow’ button to begin setting up your integration. This is where you will define the connection between Tally Forms and Discord using Pabbly Connect.
After accessing Pabbly Connect, you will need to name your workflow. For this integration, name it ‘Send Tally Forms Submission to Discord’. Choose a folder to save your workflow, such as ‘Automations’. Click on ‘Create’ to proceed.
- Select Tally Forms as the trigger application.
- Choose ‘New Response’ as the trigger event.
- Copy the provided webhook URL for later use.
Once you have set the trigger, Pabbly Connect will wait for a response from your Tally form. This step is crucial as it ensures that every new submission triggers a notification in your Discord channel.
3. Setting Up Tally Forms for Webhook Integration
Now that your workflow is created, it’s time to set up Tally Forms. Log in to your Tally account and navigate to the form you want to integrate. Click on the ‘Edit’ button for that form, then proceed to the ‘Integrations’ tab.
- Locate the Webhooks option and click ‘Connect’.
- Paste the webhook URL you copied from Pabbly Connect.
- Click ‘Connect’ to finalize the integration.
This step ensures that when a new response is submitted through Tally Forms, the data is sent to Pabbly Connect, which will then relay it to Discord.
4. Configuring Discord to Receive Messages
Next, you need to set up Discord to receive notifications from Pabbly Connect. In your Pabbly Connect workflow, select Discord as the action application. Choose ‘Send Channel Message Markdown’ as the action event.
Follow the instructions to create a new webhook in Discord. Copy the webhook URL and paste it into Pabbly Connect. Map the data fields from Tally Forms to the Discord message format.
This configuration allows Pabbly Connect to send a formatted message to your Discord channel whenever a new Tally form submission is received, ensuring your team is updated in real-time.
To ensure everything is working correctly, perform a test submission on your Tally form. After submitting the form, check your Discord channel to see if the message appears. This step is essential to confirm that Pabbly Connect is functioning as expected.
If the message appears with the correct details, your integration is successful! Now, every time a new response is submitted through Tally Forms, your Discord channel will receive a notification automatically.
By following this tutorial, you have successfully learned how to use Pabbly Connect to automate Tally Forms submissions to your Discord channel. This integration enhances team communication and ensures timely follow-ups on potential client inquiries.
