Learn how to send SMS notifications for successful Instamojo payments using Pabbly Connect in this detailed tutorial. Step-by-step guide included. Follow this definitive guide to creating powerful automated workflows with straightforward, efficiency-focused solutions that save valuable time.
To begin sending SMS notifications for successful Instamojo payments, you must access Pabbly Connect. Start by typing the URL Pabbly.com/connect in your browser. If you are an existing user, simply sign in; otherwise, sign up for a free account.
After signing in, you will be directed to the Pabbly Connect dashboard. Here, locate the ‘Create Workflow’ button on the right-hand side. Click this button to initiate a new workflow for your SMS notifications.
Once you click on ‘Create Workflow’, you will need to name your workflow. For this integration, name it something like ‘Instamojo to MSG91 Integration’. This name will help you identify the workflow later.
After naming your workflow, click on the ‘Create’ button. You will now see two important sections: Trigger and Action. The trigger is the event that starts the workflow, while the action is what happens as a result. For this setup, your trigger will be the successful payment from Instamojo.
- Select the trigger event as ‘New Sale’ from Instamojo.
With the trigger set, you will receive a webhook URL from Pabbly Connect which you will use to connect to your Instamojo account.
3. Setting Up the Webhook in Instamojo
Now that you have your webhook URL, navigate to your Instamojo account. Click on ‘Smart Pages’ to access your payment pages. Here, you can edit an existing page or create a new one.
To set up the webhook, click on the three dots next to your desired page and select ‘Edit Page’. In the settings, find the option for ‘Add Webhook’. Paste the webhook URL you copied from Pabbly Connect into the provided field. After pasting the URL, make sure to click on ‘Save and Update’ to finalize the connection.
After saving the webhook, return to Pabbly Connect. You will see a message indicating that it is waiting for a webhook response. To test this, go back to your Instamojo page and complete a test payment.
Fill in the required customer information and click on ‘Pay Now’. Once the payment is successful, go back to Pabbly Connect to check if the webhook has received the response. You should see details like payment status, amount, and buyer information.
- Complete the payment process on Instamojo.
- Check Pabbly Connect for the webhook response.
- Ensure all payment details are captured correctly.
Once the data is received, your integration setup is confirmed and ready for the next step.
5. Sending SMS Notifications via MSG91
With the payment details captured, the next step is to set up the action in Pabbly Connect to send SMS notifications. For this, select MSG91 as your action application.
Choose the action event as ‘Send Campaign’. You will need to connect your MSG91 account by entering the API key. To find your API key, log in to your MSG91 account and navigate to the SMS section to retrieve it. Paste this key back into Pabbly Connect to establish the connection.
Now, map the required fields such as mobile number, name, and other details from the webhook data you received earlier. After mapping, click on ‘Save and Send Test Request’. You should receive a confirmation message indicating that the SMS has been sent successfully.
In this tutorial, we explored how to send SMS notifications for successful Instamojo payments using Pabbly Connect. By following the steps outlined, you can automate communication with your customers seamlessly. This integration enhances customer engagement and ensures timely updates about their transactions.
