Learn how to send Slack alerts for every new YouTube comment using Pabbly Connect. Follow this step-by-step guide for seamless integration. Follow this definitive guide to creating powerful automated workflows with straightforward, efficiency-focused solutions that save valuable time.
To send Slack alerts for every new YouTube comment, you first need to access Pabbly Connect. Open your browser and go to Pabbly.com/connect. Here, you will find options to either sign in or sign up for free.
If you are new to Pabbly Connect, select ‘Sign Up Free’ to get 100 free tasks every month. For existing users, simply sign in to your account. After logging in, navigate to the Pabbly apps window and click on ‘Access Now’ under Pabbly Connect to reach the dashboard.
Now that you are on the Pabbly Connect dashboard, you can create a new workflow. Click on the ‘Create Workflow’ button located at the top right corner of the screen. You will be prompted to select a workflow builder.
  • Choose between the new beta or classic version; for this tutorial, we will use the classic version.
  • Name your workflow as ‘Send Slack Alerts for Every New YouTube Comment’.
  • Select a folder to save your workflow, such as ‘Automations’.
After naming your workflow and selecting the appropriate folder, click on the ‘Create’ button to proceed. This will set up the basic structure for your automation.
3. Setting Up the Trigger with YouTube
The next step involves setting up a trigger in Pabbly Connect. Since we want to capture new comments on your YouTube channel, select ‘YouTube’ as your trigger application and ‘New Comment on a Channel’ as the trigger event. Click on ‘Connect’ to establish the connection.
If your YouTube account isn’t already linked, click on ‘Add New Connection’ and follow the prompts to connect your YouTube account. Once connected, select your YouTube channel and specify the maximum number of results you want to capture. For instance, you can set it to ‘1’ to get the latest comment.
4. Getting Video Details from YouTube
After setting up the trigger, the next step is to retrieve the video details associated with the comment. In this action step, select ‘YouTube’ again and choose ‘Get Video by ID’ as the action event. Click on ‘Connect’ to use the existing connection you made earlier. using Pabbly Connect
  • Map the video ID from the previous step to dynamically fetch details.
  • This ensures that every time a new comment is received, the correct video details are retrieved.
Once you have mapped the video ID, click on ‘Save and Send Test Request’. This action will fetch the video title and prepare it for sending to Slack.
5. Sending Alerts to Slack
With the video details in hand, it’s time to notify your team via Slack. Select ‘Slack’ as your action application and choose ‘Send Channel Message’ as the action event. Click on ‘Connect’ to establish a new connection or select an existing one. using Pabbly Connect
When prompted, enter the token type (user or bot) and select the appropriate channel ID where you want to send the alerts. In the message field, create a message format that includes the video title, commenter name, and the comment itself. Use the mapping feature to dynamically insert these details into your message.
After entering all the required fields, click on ‘Save and Send Request’ to send the alert to your Slack channel. You should see a confirmation that the message has been sent successfully. Your team will now receive alerts for every new comment on your YouTube channel, ensuring quick responses and engagement.
In this tutorial, we successfully demonstrated how to send Slack alerts for every new YouTube comment using Pabbly Connect. By following the outlined steps, you can automate the process of sharing comments with your team, enhancing communication and engagement.
