Learn how to integrate Simvoly with Twilio to send order confirmation SMS using Pabbly Connect. Step-by-step guide included. Master proven automation processes with practical implementation examples and strategic recommendations you can apply immediately in your workflow.
To send a Simvoly order confirmation message via SMS, you first need to access Pabbly Connect. Start by visiting the Pabbly website and navigate to the Pabbly Connect section.
Click on ‘Sign Up Free’ to create a new account, or ‘Sign In’ if you already have one. Once logged in, go to the Pabbly Connect dashboard where you can create a new workflow.
In the Pabbly Connect dashboard, click on ‘Create Workflow’ and name it, for example, ‘Simvoly to Twilio’. This workflow will handle the integration between Simvoly and Twilio. using Pabbly Connect
- Click on ‘Create’ to start setting up your workflow.
- You will see two main windows: the Trigger window and the Action window.
In the Trigger window, search for ‘Simvoly’ and select it. Choose ‘New Order’ as the trigger event. This setup will allow Pabbly Connect to receive new order details from your Simvoly store.
3. Connecting Simvoly to Pabbly Connect
After selecting the trigger event, Pabbly Connect will provide a webhook URL. Copy this URL, as it will be used to connect your Simvoly store to Pabbly Connect. using Pabbly Connect
Go to your Simvoly account, access the website settings, and navigate to the Applications section. Click on ‘Add Application’ and select ‘Connect Webhook’. Paste the copied webhook URL into the destination URL field.
- Set the event to ‘New Order’ to send order details to Pabbly Connect.
- Click ‘Save’ to establish the connection.
Now, every time a new order is placed on your Simvoly website, the details will be sent to Pabbly Connect automatically.
4. Setting Up Twilio for SMS Confirmation
Once your Simvoly store is connected, you need to set up Twilio to send SMS messages. In the Action window of Pabbly Connect, search for ‘Twilio’ and select it. Choose ‘Send SMS Message’ as the action event. using Pabbly Connect
Next, connect your Twilio account by entering the Account SID and Authorization Token from your Twilio dashboard. This will allow Pabbly Connect to send SMS messages through your Twilio account.
Map the SMS body content with customer details received from Simvoly. Specify the sender’s number from your Twilio account.
Finally, map the recipient’s mobile number from the order details and ensure it includes the country code, then click ‘Save and Send Test Request’.
5. Testing the Integration
To confirm that your integration is working, place a test order on your Simvoly website. After completing the order, check Pabbly Connect for the response from the new order trigger.
If set up correctly, you should see the order details populated in Pabbly Connect. This includes the customer’s name, email, and the product ordered. Pabbly Connect will then send an SMS confirmation through Twilio.
You will receive a confirmation SMS at the customer’s mobile number. The SMS will include a personalized message with the customer’s name and product details.
This confirms that the integration between Simvoly and Twilio via Pabbly Connect is functioning correctly and automating your order confirmations.
In this tutorial, we demonstrated how to use Pabbly Connect to integrate Simvoly with Twilio for sending SMS order confirmations. This automation streamlines your order processing and enhances customer communication.
