Learn how to automate Pushover notifications for Razorpay payments using Pabbly Connect. Step-by-step guide for seamless integration. Discover hidden automation capabilities within your existing tools. This guide shows you how to connect your essential applications and permanently eliminate redundant manual processes.
1. Setting Up Pabbly Connect for Razorpay Integration
To send Pushover notifications on Razorpay payments, you first need to set up Pabbly Connect. This platform allows you to automate workflows between Razorpay and Pushover effectively. Start by signing up for a free account on Pabbly Connect, which can be done in just a few minutes.
After signing in, navigate to your dashboard and create a new workflow. Click on the ‘Create Workflow’ button, name it something like ‘Razorpay to Pushover’, and select the appropriate folder. This sets the stage for your automation.
2. Connecting Razorpay to Pabbly Connect
In this step, you will connect Razorpay to Pabbly Connect to capture payment details. Begin by selecting Razorpay as your trigger app. The trigger event should be set to ‘Payment Captured’. This will enable Pabbly Connect to listen for any new payments processed through your Razorpay account.
- Select Razorpay from the app list.
- Choose ‘Payment Captured’ as the trigger event.
Next, go to your Razorpay account settings, navigate to the ‘Webhooks’ section, and add a new webhook. Paste the copied URL, select ‘Payment Captured’ as the active event, and save the settings. This ensures that every payment processed will trigger a notification through Pabbly Connect.
3. Testing the Integration with a Dummy Payment
Now that Razorpay is connected to Pabbly Connect, it’s time to test the integration. You need to make a dummy payment to see if the webhook captures the details correctly. Use a test payment page and fill in the required customer details.
Once the payment is processed, return to your Pabbly Connect dashboard. You should see that it is waiting for a webhook response. After the payment, Pabbly Connect will display the payment details received from Razorpay, including the customer’s name, email, and payment amount.
4. Sending Notifications to Pushover
The next step involves sending the captured payment details to Pushover using Pabbly Connect. Add a new action step and select Pushover as the app. Choose the action event as ‘Push Notification’. Connect your Pushover account by entering the API token.
In the message field, you can customize the notification. Include dynamic fields from Razorpay, such as customer name, email, and payment amount. Ensure you enable HTML parsing if you want to format the message properly. Finally, test this action step to verify that the notification is sent successfully to your Pushover app.
By following these steps, you can successfully automate Pushover notifications for Razorpay payments using Pabbly Connect. This integration allows you to receive real-time updates on payment activities, enhancing your operational efficiency. Try it out today to streamline your payment notifications!
