Learn how to automate Discord notifications for FlexiFunnels purchases using Pabbly Connect in this step-by-step guide. Eliminate manual repetitive tasks from your workflow. Discover proven automation methods with intuitive steps designed for efficiency-minded professionals.
Accessing Pabbly Connect for Discord Integration
To send Discord channel messages on FlexiFunnels purchase, you first need to access Pabbly Connect. Start by navigating to the Pabbly Connect website and signing into your account. If you’re a new user, you can sign up for a free account, which provides 100 free tasks each month.
Once logged in, you will see all the available applications. Click on the Pabbly Connect option to access the dashboard. From there, you can create a new workflow that will automate the process of sending messages to your Discord channel whenever a purchase is made through FlexiFunnels.
After accessing Pabbly Connect, click on the ‘Create Workflow’ button located at the top right corner of the dashboard. A dialog box will appear asking for the workflow name and folder selection. Name your workflow as ‘Send Discord Channel Messages on FlexiFunnels Purchase’ and select a folder to save it.
For this integration, you will need to set up a trigger and an action. The trigger will be FlexiFunnels, specifically the ‘New Purchase’ event. This allows Pabbly Connect to capture any new purchase made through FlexiFunnels. Once you select this trigger, Pabbly Connect will provide you with a webhook URL to facilitate the connection.
Setting Up the Trigger with FlexiFunnels
To set up the trigger in Pabbly Connect, copy the webhook URL provided after selecting the ‘New Purchase’ event. Next, log into your FlexiFunnels account and navigate to the product page where you manage purchases. Locate the product you want to connect and click on the ‘Edit’ button.
In the product settings, go to the ‘Set Rules’ option and click on the ‘Add Product Rules’ button. Here, select ‘Product is Purchased’ for all pricing options and choose ‘Webhook’ as the action. Paste the copied webhook URL from Pabbly Connect, and save the changes. This will ensure that every time a purchase is made, the information is sent to Pabbly Connect.
Testing the Integration with Pabbly Connect
After setting up the webhook in FlexiFunnels, it’s time to test the integration. Perform a test purchase by filling in the required participant details and completing the order. Once the purchase is confirmed, return to your Pabbly Connect workflow to check if the response has been captured.
After the test purchase, you should see a successful response in Pabbly Connect showing the participant’s details. This indicates that the connection between FlexiFunnels and Pabbly Connect is working correctly, and the trigger is set up properly. You can now proceed to set up the action step to send notifications to your Discord channel.
Sending Notifications to Discord Using Pabbly Connect
To notify your Discord community about new participants, select Discord as the action application in Pabbly Connect. Choose the action event as ‘Send Channel Message’ and click on the connect button. You will be prompted to enter the webhook URL for your Discord channel where the messages will be sent.
To obtain the webhook URL, go to your Discord server settings, navigate to the integrations section, and create a new webhook. Copy the URL and paste it into Pabbly Connect. Customize the message you want to send, including participant details that you mapped from the previous step. Once everything is set, click on ‘Save and Send Test Request’ to verify that the notification is sent successfully to your Discord channel.
In this tutorial, we explored how to use Pabbly Connect to send Discord channel messages whenever a new purchase is made on FlexiFunnels. This automation enhances communication within your gaming community and streamlines the registration process for your tournaments. By following these steps, you can easily set up similar integrations for various applications using Pabbly Connect.
