Learn how to automate sending daily SMS with inspirational quotes using Pabbly Connect. Follow this detailed tutorial to set up your workflow seamlessly. Discover hidden automation capabilities within your existing tools. This guide shows you how to connect your essential applications and permanently eliminate redundant manual processes.
1. Setting Up Pabbly Connect for SMS Automation
To begin sending daily SMS with inspirational quotes, the first step is to access Pabbly Connect. Navigate to the Pabbly Connect website by typing the URL Pabbly.com/connect in your browser.
If you’re a new user, you can sign up for free. Existing users should simply sign in. Once logged in, click on the ‘Create Workflow’ button to initiate a new automation process.
2. Scheduling the Workflow in Pabbly Connect
In this step, you will set up a schedule for your workflow to run daily. Choose the ‘Schedule’ feature from Pabbly Connect to specify how often you want the workflow to execute. Set the time for this to occur, for instance, at 10 AM UTC. using Pabbly Connect
- Select the ‘Schedule’ option.
- Set the frequency to ‘Every Day’.
- Specify the time (e.g., 10 AM UTC).
After setting the schedule, click on ‘Save’ to confirm your settings. This step ensures that your SMS will be sent automatically at the designated time every day.
3. Integrating Google Sheets with Pabbly Connect
Next, you will integrate Google Sheets to retrieve customer data. Select Google Sheets as your action application and choose the ‘Get Rows’ action event. Connect your Google Sheets account by signing in and authorizing access. using Pabbly Connect
Once connected, specify the spreadsheet that contains your customer information. You will need to set the range to A2:C4 or a broader range like A2:C, depending on your data.
4. Sending SMS Using Twilio Through Pabbly Connect
After retrieving customer data, the next step is to send the SMS using Twilio. Choose Twilio as your action application and select the ‘Send SMS’ action event. Connect your Twilio account by entering the Account SID and Authorization Token. using Pabbly Connect
- Enter the SMS body, including the customer’s name and the inspirational quote.
- Map the recipient’s number from the Google Sheets data.
- Test the SMS sending function to ensure everything works correctly.
Finally, click on ‘Save and send test request’ to verify that the SMS is sent successfully. You should receive a confirmation message indicating that the SMS was dispatched.
5. Conclusion: Automate Your SMS with Pabbly Connect
By following these steps, you can effectively automate sending daily SMS with inspirational quotes using Pabbly Connect. This integration not only saves time but also ensures that your customers receive motivational messages regularly.
Pabbly Connect serves as the central platform for connecting various applications like Google Sheets and Twilio, making the automation process seamless and efficient. Start your automation journey today!
