Learn how to send automated WhatsApp messages to your automobile spare parts business leads using Pabbly Connect. This detailed guide provides step-by-step instructions for integration.
1. Accessing Pabbly Connect to Set Up Automation
To send automated WhatsApp messages to your automobile spare parts business leads, you first need to access Pabbly Connect. Start by signing in to your Pabbly account. If you are new, click on the ‘Sign Up for Free’ button to create an account and receive 100 free tasks every month.
After logging in, navigate to the ‘All Applications’ page and click on Pabbly Connect. From there, access your dashboard to begin creating your workflow for automation.
In this section, you will create a workflow to automate WhatsApp messaging. Click on the ‘Create Workflow’ button located at the top right corner of your dashboard. Name your workflow as ‘Send Automated WhatsApp Message to Facebook Leads’ and save it in the folder named ‘Facebook Lead Ads’. using Pabbly Connect
- You will see options for trigger and action applications.
- Select Facebook Lead Ads as the trigger application.
Once you select Facebook Lead Ads, choose ‘New Lead Instant’ as the trigger event. This setup allows Pabbly Connect to initiate the workflow automatically whenever a new lead is generated through your Facebook ads.
Next, you need to establish a connection between Facebook Lead Ads and Pabbly Connect. Click on the ‘Connect’ button in the trigger window. A prompt will appear asking you to log into your Facebook account if you haven’t done so already.
After successful authorization, select the Facebook page that you have created for your automobile spare parts business. You will also need to select the lead generation form associated with that page.
- Choose your page (e.g., ‘Tire Store’).
- Select the lead form (e.g., ‘Tire Store Contact Form’).
After selecting both, click on ‘Save and Test Request’. This will prepare Pabbly Connect to receive data from Facebook Lead Ads.
4. Sending Automated WhatsApp Messages via Pabbly Connect
Now, it’s time to configure the action application to send WhatsApp messages. In the action window, select ‘Vati’ as the application to send the WhatsApp message. Choose the action event as ‘Send Template Message’.
To connect Vati with Pabbly Connect, click on the ‘Connect’ button and provide the API endpoint and access token from your Vati account. Copy the necessary details from Vati API documentation and paste them into the respective fields in Pabbly Connect.
Map the phone number field from the Facebook lead data. Select the WhatsApp template you created for leads.
Once you have configured these settings, click on ‘Save and Test Request’ to send a test WhatsApp message to the lead. This confirms that your integration is working correctly.
5. Testing the Integration Success
After completing the setup, it’s crucial to test the integration to ensure everything functions as intended. Use the Meta for Developers tool to create a test lead. Fill in the required fields and submit the lead form.
Upon successful submission, return to Pabbly Connect to check if the lead data has been captured. You should see the details such as full name, email, and phone number from the test lead.
Confirm that the WhatsApp message is received on the specified number. Check that the message includes the lead’s name dynamically.
If the test is successful, your automation is complete. Now, every time a new lead comes through Facebook, an automated WhatsApp message will be sent to that lead, enhancing your customer engagement.
Using Pabbly Connect, you can effortlessly send automated WhatsApp messages to your automobile spare parts business leads. This integration not only streamlines your communication but also enhances customer engagement effectively.
