Learn how to automate WhatsApp messages to Facebook leads for your astrology business using Pabbly Connect. Step-by-step tutorial included. Learn to create powerful connections between your critical applications without requiring specialized programming knowledge or extensive technical background.
To send automated WhatsApp messages to Facebook leads for your astrology business, first, access Pabbly Connect. This integration platform allows you to connect various applications seamlessly. Start by signing into your existing account or create a new one for free, which includes 100 tasks monthly.
After logging in, navigate to the Pabbly Connect dashboard. From there, click on the ‘Create Workflow’ button located in the top right corner. Here, name your workflow something descriptive like ‘Send Automated WhatsApp Messages to Facebook Leads’ and save it under a relevant folder, such as ‘Facebook Lead Ads.’
2. Setting Up the Trigger Application in Pabbly Connect
In this step, you will set Facebook Lead Ads as the trigger application in Pabbly Connect. This means that every time a new lead is generated through Facebook, the automation will be triggered. Select ‘Facebook Lead Ads’ as your trigger application and choose ‘New Lead Instant’ as the trigger event.
- Select Facebook Lead Ads as the trigger application.
- Choose the trigger event as New Lead Instant.
- Click on ‘Connect’ to establish a connection with your Facebook account.
Once connected, choose the Facebook page associated with your astrology business and select the lead generation form you wish to use. This setup will ensure that any new leads from your Facebook ads will automatically trigger the workflow in Pabbly Connect.
3. Testing the Facebook Lead Integration
After setting up the trigger, it’s crucial to test the integration to ensure it works correctly. Use the Meta for Developers tools to create a test lead. Navigate to the Lead Ads Testing Tool, select your Facebook page, and fill in the required lead details such as email, full name, and phone number.
Once you submit the test lead, return to Pabbly Connect to check if the lead details have been captured successfully. You should see the response with all relevant information such as email, full name, and phone number. This confirms that the integration is functioning as expected.
4. Connecting WhatsApp for Automated Messaging
Now that you have successfully set up the trigger, it’s time to connect WhatsApp using Wati as your action application in Pabbly Connect. Select Wati and choose the action event ‘Send Template Message’. This will allow you to send an automated WhatsApp message to the leads captured from Facebook.
- Connect Wati by entering the API endpoint and access token.
- Map the WhatsApp number from the lead response you received.
- Select the message template you wish to use for the WhatsApp message.
By mapping the WhatsApp number, you ensure that the message is sent to the correct lead. After completing these steps, save the configuration and send a test request to verify that the automated message is sent successfully.
5. Finalizing and Testing the Automated WhatsApp Messages
With everything set up, it’s time to finalize your automation in Pabbly Connect. After sending the test request, check if the automated WhatsApp message has been successfully sent to the test lead. You should see the message with the lead’s name and the body content you defined in your template.
This confirms that your automation is now live. Whenever a new lead is generated through Facebook Lead Ads, an automated WhatsApp message will be sent to them. This integration not only saves time but also enhances your engagement with potential clients in your astrology business.
In conclusion, using Pabbly Connect allows you to effortlessly send automated WhatsApp messages to Facebook leads for your astrology business. This automation enhances communication and ensures no lead goes unattended. Start integrating today to streamline your processes!
