Learn how to automate sending 99acres real estate leads to Mailchimp using Pabbly Connect. Follow our step-by-step guide for seamless integration. Explore efficient methods for automating routine tasks with clear, concise instructions suited for both newcomers and experienced professionals.
To start automating the process of sending 99acres real estate leads to Mailchimp, you need to access Pabbly Connect. Begin by visiting the Pabbly Connect website at www.Pabbly.com/connect. This platform will serve as the central hub for your automation tasks.
If you are a new user, click on the ‘Sign Up Free’ button to create an account and receive 100 free tasks each month. Existing users can simply sign in to access their dashboard. Once logged in, navigate to the Pabbly Connect section by clicking on the ‘Access Now’ button.
Once you’re in Pabbly Connect, the next step is to create a new workflow. Click on the ‘Create Workflow’ button located at the top right corner of the dashboard. You will be prompted to select a workflow builder; choose the ‘New Beta’ version for a more modern experience.
- Select a suitable name for your workflow, such as ‘Send 99 Acres Real Estate Leads to Mailchimp Automatically’.
- Choose a folder to save your workflow, such as ‘Automations’.
After naming your workflow and selecting a folder, click on the ‘Create’ button to finalize the setup. You will now see two main principles of automation: triggers and actions. This setup will allow you to automate the addition of new leads from 99acres to Mailchimp.
To automate the workflow, click on the ‘Add Trigger’ button and select ’99acres’ as your trigger application. Choose ‘New Leads’ as the event. After clicking on ‘Connect’, you will receive a webhook URL, which will be used to connect your 99acres account with Pabbly Connect.
Copy the webhook URL and provide it to your 99acres account team to activate the integration. Once they add the URL, you will start receiving lead information in your Pabbly Connect workflow. After setting up the trigger, you can test it by waiting for a dummy lead response.
4. Adding Action to Mailchimp in Pabbly Connect
Next, you need to set up an action step. Click on the ‘Add Action’ button, select ‘Mailchimp’ as your action application, and choose ‘Add New Member with Custom Fields’ as the event. Click on ‘Connect’ to create a new connection. using Pabbly Connect
- You will need to enter your Mailchimp API key and data center.
- To find your API key, go to your Mailchimp account, click on your profile, select ‘Account and Billing’, then ‘Extras’ and finally ‘API Keys’.
After entering the required information, select the audience list where you want to add the new subscriber. Map the data fields from the trigger step to ensure that the lead’s email address and other details are dynamically added to your Mailchimp account.
5. Finalizing the Integration in Pabbly Connect
After mapping the necessary fields, click on the ‘Save and Send Test Request’ button in Pabbly Connect. You should receive a successful response indicating that a new subscriber has been created in your Mailchimp account. Check your Mailchimp audience to confirm that the new lead has been added successfully.
This seamless integration allows you to automatically send 99acres real estate leads to Mailchimp, ensuring that your marketing efforts are efficient and effective. With Pabbly Connect, you can easily manage your leads and improve your outreach efforts.
In this tutorial, we explored how to use Pabbly Connect to automate the process of sending 99acres real estate leads to Mailchimp. By following the outlined steps, you can enhance your lead management and marketing strategies effectively.
