Learn how to rewrite old WordPress blogs for SEO boost using Pabbly Connect to integrate Google Sheets, OpenAI, and WordPress effectively. Discover how to seamlessly connect your essential tools through accessible instructions that make powerful automation available to professionals at every skill level.
To start rewriting old WordPress blogs for an SEO boost, you need to access Pabbly Connect. This platform enables seamless integration between various applications, including Google Sheets and WordPress. Begin by visiting the Pabbly Connect website to either sign up for a new account or log in to your existing account.
Once logged in, navigate to the dashboard and click on the ‘Create Workflow’ button. Name your workflow, for example, ‘AI Agent for WordPress Blog’. Select the appropriate folder in your Pabbly Connect account and click ‘Create’. This sets the foundation for your integration process.
2. Setting Up the Trigger with Google Sheets
The next step involves setting up a trigger in Pabbly Connect that captures new entries from your Google Sheets containing old blog details. Search for the Google Sheets application and select the trigger event as ‘New or Updated Spreadsheet Row’. This ensures that every time a new row is added, the AI agent will activate.
- Select the correct Google Sheet where your old blog details are stored.
- Go to Google Sheets, navigate to Extensions > Add-ons, and install the Pabbly Connect Webhooks add-on.
After installation, refresh your Google Sheets and configure the add-on by pasting the webhook URL. Set the trigger column to the last column of your sheet, which will activate when new data is entered. Click ‘Send Test’ to confirm the connection, and you should see a successful response in Pabbly Connect.
3. Sending Data to OpenAI for Content Generation
Now that you have set up the trigger, the next step is to send the old blog content to OpenAI for rewriting. In Pabbly Connect, add a new action step and choose OpenAI as the application. Select the action event as ‘Chat GPT Structured AI Output’ to facilitate structured data retrieval.
Connect your OpenAI account by entering the API key, which you can obtain from your OpenAI dashboard. After successfully connecting, specify the model you wish to use, such as GPT-3. Define the prompts for the AI, including both system and user prompts to guide the content generation process.
- Enter the system prompt that defines the context for the AI.
- Map the old blog title, content, and excerpt from the Google Sheets responses to the corresponding fields in OpenAI.
- Set the response format to JSON schema to ensure structured output.
After configuring these settings, click ‘Save and Send Test Request’. If successful, you will receive updated blog content ready for WordPress.
4. Updating WordPress Posts with New Content
With the new content generated by OpenAI, it’s time to update your WordPress blog. In Pabbly Connect, add another action step and select WordPress as the application. Choose the action event ‘Update a Post’ to modify the existing blog post with the new content.
Connect your WordPress account by entering your username, password, and base URL. Once connected, you will map the post ID from your Google Sheets data to ensure the correct blog post is updated. Next, map the updated title, content, and excerpt from the OpenAI responses.
Select the post type you wish to update. Ensure the status is set to ‘Published’ or ‘Draft’ based on your preference. Click ‘Save and Send Test Request’ to complete the update.
Once the update is successful, your WordPress post will reflect the new SEO-optimized content generated by the AI agent.
5. Bulk Updating Blogs Using Pabbly Connect
If you have multiple old blog posts to update, Pabbly Connect allows you to send all data at once. After setting up the workflow, go back to your Google Sheets and navigate to Extensions > Pabbly Connect, then click on ‘Send All Data’. This action will trigger the AI agent for each row in your spreadsheet.
As each row is processed, Pabbly Connect will send the old blog details to OpenAI, generate new content, and update each corresponding WordPress post automatically. This bulk process saves time and ensures consistency across your blog updates.
After initiating the bulk update, you can check the history of the workflow in Pabbly Connect to monitor the progress and confirm successful updates. This feature makes managing multiple blog posts efficient and effective, enhancing your SEO efforts.
In this tutorial, we explored how to effectively rewrite old WordPress blogs for an SEO boost using Pabbly Connect. By integrating Google Sheets, OpenAI, and WordPress, you can automate the process of updating your blog content to meet current SEO standards. This not only saves time but also improves the visibility of your blogs in search engines.
