Learn how to seamlessly register LinkedIn leads for WebinarJam sessions using Pabbly Connect. This detailed tutorial guides you through the setup process step-by-step. Discover hidden automation capabilities within your existing tools. This guide shows you how to connect your essential applications and permanently eliminate redundant manual processes.
1. Accessing Pabbly Connect for LinkedIn and WebinarJam Integration
To register LinkedIn leads for WebinarJam sessions, start by accessing Pabbly Connect. This powerful automation tool allows you to connect multiple applications without any programming knowledge.
Open a new tab in your browser and search for Pabbly Connect by entering ‘Pabbly.com/connect’. Once on the landing page, you can either sign in if you’re an existing user or click on ‘Sign up for free’ to create a new account. This free trial gives you 100 tasks per month to explore the application.
After signing in, navigate to the Pabbly Connect dashboard and click on the ‘Create Workflow’ button. This is where you will set up the connection between LinkedIn and WebinarJam using Pabbly Connect.
  • Choose the new workflow builder for a modern interface.
  • Name your workflow as ‘Register LinkedIn Leads for WebinarJam Sessions’.
Once you’ve named your workflow and selected a folder, click on ‘Create’ to open the workflow window. This window is crucial as it contains the trigger and action settings necessary for your automation.
3. Setting Up the Trigger with LinkedIn in Pabbly Connect
To set up the trigger, click on the ‘Add Trigger’ button. Search for LinkedIn and select it as your trigger application. Then, choose the trigger event as ‘Lead Notifications’ and click on ‘Connect’. using Pabbly Connect
If you haven’t connected your LinkedIn account yet, click on ‘Add a New Connection’. Enter your LinkedIn credentials and sign in. After connecting, select your sponsor’s ad account and proceed to save and send a test request. This will await a webhook response from LinkedIn.
4. Testing the LinkedIn to WebinarJam Integration
To capture the webhook response, perform a test submission by opening your LinkedIn campaign. Fill in the required fields, such as email address and phone number, and submit the form. Once submitted, Pabbly Connect will capture the response, which includes all lead details. using Pabbly Connect
  • Check that Pabbly Connect receives the lead details successfully.
  • Verify the captured details like first name, last name, email, and phone number.
Once the trigger step is successfully set up, your workflow will automatically trigger every time a new lead is generated from LinkedIn.
5. Finalizing the Registration in WebinarJam via Pabbly Connect
Next, you will add an action step to register the lead in WebinarJam. Click on the ‘Add New Action Step’ and select WebinarJam as your action application. Choose the action event as ‘Register a Person to Webinar’ and click on ‘Connect’. using Pabbly Connect
If you have not connected your WebinarJam account yet, click on ‘Add a New Connection’. You will need to enter your API key from your WebinarJam account under the API custom integration settings. Once connected, select the specific webinar for which you want to register leads.
Map the lead details from the previous step to the registration fields in WebinarJam. This ensures that every new lead is automatically registered with their details. After completing the mapping, click on ‘Save and Send Test Request’ to finalize the setup.
By following these steps, you can effectively register LinkedIn leads for your WebinarJam sessions using Pabbly Connect. This integration automates the process, ensuring no lead is missed while saving you time and effort.
