Learn how to register Housing.com renters for WhatsApp assistance by integrating Facebook with Pabbly Connect. Follow our step-by-step guide for seamless automation. Master proven automation processes with practical implementation examples and strategic recommendations you can apply immediately in your workflow.
To start the process of registering Housing.com renters for WhatsApp assistance, you first need to access Pabbly Connect. Open your browser and type in Pabbly.com/connect to reach the Pabbly Connect homepage.
Once on the homepage, you will see options to either sign in or sign up. If you are a new user, click on ‘Sign Up Free’ to create an account and receive 100 free tasks per month. Existing users can directly sign in.
After signing in to Pabbly Connect, you will be directed to the dashboard. Here, click on the ‘Create Workflow’ button located at the top right corner. This will open a dialog box where you can name your workflow.
For this integration, name the workflow ‘Register Housing.com Renters for WhatsApp Assistance’. You also have the option to select a folder to save your workflow. Choose an appropriate folder like ‘Automations’ for easy organization.
- Click on ‘Create’ to finalize your workflow.
- Select the trigger application as Housing.com.
- Choose the event as ‘New Leads’.
This setup will allow Pabbly Connect to trigger the automation every time a new lead is received from Housing.com.
In this step, you will configure the trigger for your workflow. Select Housing.com as your trigger application and set the event to ‘New Leads’. Click on the ‘Connect’ button to establish the connection. using Pabbly Connect
Pabbly Connect will provide you with a webhook URL. This URL is essential as it will connect Housing.com with Pabbly Connect. Copy this webhook URL and follow the instructions provided by Housing.com to integrate it into their system.
- Ensure that you have activated your Housing.com account to start receiving leads.
- Test the integration by generating a sample lead.
Once the test lead is received, you can proceed to the next step in your workflow.
4. Configuring WhatsApp Action Step in Pabbly Connect
Now that you have set up the trigger, it is time to configure the action step. Select WhatsApp Cloud API as your action application. The event should be set to ‘Send Template Message’. Click on the ‘Connect’ button to set up the connection.
You will need to enter details such as the Access Token, Phone Number ID, and WhatsApp Business Account ID. These details can be found in your WhatsApp Cloud API account settings. Once entered, click on ‘Save’ to establish the connection with Pabbly Connect.
Map the phone number field from the trigger step to ensure the message is sent to the correct lead. Select the template message you created for leads.
This setup ensures that every time a new lead is registered, an automated WhatsApp message will be sent to them via Pabbly Connect.
5. Testing the Integration
With the workflow configured, it’s essential to test the integration to ensure everything is working smoothly. Generate a test lead through Housing.com and monitor the response in Pabbly Connect.
Once the test lead is processed, check your WhatsApp account to confirm that the automated message has been received. This message should provide the lead with information and assistance regarding their rental needs.
By following these steps, you have successfully set up an automated process to register Housing.com renters for WhatsApp assistance using Pabbly Connect. This integration not only enhances engagement but also streamlines communication with potential renters.
In this tutorial, we explored how to use Pabbly Connect to automate the registration of Housing.com renters for WhatsApp assistance. By integrating these platforms, you can enhance engagement and improve your rental service efficiency.
