Learn how to seamlessly register Facebook leads for WebinarJam sessions using Pabbly Connect. Follow our step-by-step guide for easy integration. Implement the precise methodologies leading organizations use to automate repetitive tasks, illustrated with practical examples designed for immediate application.
1. How to Access Pabbly Connect for Facebook Leads
To register Facebook leads for WebinarJam sessions, first, you need to access Pabbly Connect. Open your browser and go to the Pabbly Connect landing page by entering ‘Pabbly.com/connect’. This platform will enable the necessary integration between Facebook and WebinarJam.
Once on the Pabbly Connect page, you will see options to sign in or sign up. If you are a new user, click on ‘Sign up for free’ to get started. Existing users can simply click on ‘Sign in’ to access their accounts. After signing in, select ‘Access Now’ under Pabbly Connect to reach your dashboard.
After accessing your Pabbly Connect dashboard, the next step is to create a workflow. Click on the button labeled ‘Create Workflow’. You will then be prompted to select a workflow builder. Choose the new workflow builder for a modern interface. using Pabbly Connect
- Enter the workflow name: ‘Register Facebook Leads for WebinarJam Sessions.’
- Select the folder to save your workflow, e.g., ‘Automations.’
Once you have entered the workflow name and selected the folder, click on the ‘Create’ button. This action will open the workflow window where you will set up triggers and actions for your automation. Triggers are the events that start the workflow, while actions are what happens as a result.
3. Setting Up the Trigger for Facebook Lead Ads
To register leads, you need to set up a trigger in Pabbly Connect. Click on ‘Add Trigger’ and select ‘Facebook Lead Ads’ as your trigger application. For the trigger event, choose ‘New Lead Instant’ to capture leads as soon as they come in.
Next, connect your Facebook Lead Ads account by selecting ‘Add a New Connection’. You will be prompted to choose your Facebook account and grant the necessary permissions. After connecting, select the page name and lead form you want to use. If your forms do not appear, use the ‘Refresh Fields’ button to load them.
4. Creating an Action to Register Leads in WebinarJam
Now that you have set up the trigger, it’s time to create the action in Pabbly Connect. Click on ‘Add New Action Step’ and select ‘WebinarJam’ as your action application. For the action event, choose ‘Register a Person to Webinar’.
- Add a new connection by entering your WebinarJam API key.
- Select the webinar you want to register leads for.
Map the lead details from the previous step, such as first name, last name, and email address, to the corresponding fields in WebinarJam. This mapping allows Pabbly Connect to automatically fill in the details from Facebook leads into your webinar registration.
5. Testing Your Integration with Pabbly Connect
After setting up the action, it’s crucial to test the integration. In your Pabbly Connect workflow, click on ‘Save and Send Test Request’. This will initiate a test submission to ensure everything is functioning correctly. You will need to perform a test submission via the Meta for Developers Lead Ads Debug Tool. using Pabbly Connect
Once you submit a test lead, return to your Pabbly Connect workflow to verify that the details have been captured successfully. If the test is successful, you will see the lead information displayed in the workflow, confirming that the integration is working as intended. Now, every time a new lead is captured on Facebook, they will be automatically registered in your WebinarJam session.
Using Pabbly Connect, you can efficiently register Facebook leads for WebinarJam sessions with minimal effort. This automation saves time and ensures your leads are seamlessly integrated into your webinar platform. Try this powerful integration today to enhance your lead management process!
