Learn how to automate pushing Elementor leads into HubSpot using Pabbly Connect. This step-by-step guide covers the integration process with tags. Eliminate manual repetitive tasks from your workflow. Discover proven automation methods with intuitive steps designed for efficiency-minded professionals.
To start pushing Elementor leads into HubSpot, the first step is accessing Pabbly Connect. This powerful automation tool allows you to connect multiple applications seamlessly. Open a new tab in your browser and search for Pabbly Connect to get started.
Once you are on the Pabbly Connect website, you can either sign up for a new account or log in if you are an existing user. After logging in, you will be redirected to the dashboard where you can manage all your automation workflows.
In this section, we will create a new workflow in Pabbly Connect to facilitate the integration. Click on the ‘Create Workflow’ button located at the top right corner of the dashboard. You will be prompted to name your workflow, so label it appropriately, such as ‘Elementor Leads to HubSpot’.
  • Click on the ‘Create’ button after naming your workflow.
  • You will see two sections: Trigger and Action.
  • Select ‘Elementor’ as the trigger application.
After setting up the trigger, you will need to choose the event that starts this workflow. Select the ‘New Form Submission’ event from the list. This will ensure that every time a new lead is submitted through your Elementor form, it triggers the workflow.
3. Setting Up the Elementor Trigger in Pabbly Connect
Next, it’s time to set up the Elementor trigger using Pabbly Connect. After selecting the trigger event, a unique Webhook URL will be generated. This URL is crucial for connecting Elementor to Pabbly Connect.
Copy the generated Webhook URL and head over to your Elementor form settings. In the form settings, find the ‘Webhook’ option. Paste the copied URL into the appropriate field. This will allow Elementor to send data to Pabbly Connect whenever a form is submitted.
  • Make sure to enable the Webhook option in Elementor.
  • Save the changes to your Elementor form.
Once the Webhook is set up, submit a test entry in your Elementor form to ensure that data is being captured correctly in Pabbly Connect. You should see the response received successfully on your Pabbly dashboard.
4. Configuring HubSpot Action in Pabbly Connect
After successfully setting up the Elementor trigger, the next step is to configure the action in Pabbly Connect that will push the captured leads into HubSpot. Select ‘HubSpot’ as the action application.
Choose the action event, which will be to ‘Create Contact’ in HubSpot. This action will create a new contact in your HubSpot account whenever a lead is submitted through Elementor. You will then be prompted to connect your HubSpot account to Pabbly Connect.
Select ‘Add New Connection’ to link your HubSpot account. Authorize Pabbly Connect to access your HubSpot account.
Once connected, map the fields from the Elementor form to the corresponding fields in HubSpot, ensuring that all necessary information is transferred accurately. This mapping process is crucial for the integration to work effectively.
5. Adding Tags to HubSpot Contacts
Finally, let’s explore how to add tags to the contacts created in HubSpot through Pabbly Connect. After creating the contact, you can add tags to categorize your leads effectively. This is done within the HubSpot action settings in Pabbly Connect.
To add tags, navigate to the ‘Properties’ section in the action settings, where you can specify the tags you want to apply to the new contact. This helps in organizing your leads based on different criteria.
Choose the appropriate tags based on your marketing strategy. Save the workflow after configuring the tags.
With this setup, every time a lead is submitted through Elementor, a new contact will be created in HubSpot with the specified tags, streamlining your lead management process.
By following this tutorial, you have successfully learned how to push Elementor leads into HubSpot using Pabbly Connect. This integration not only automates the process but also enhances your lead management by adding tags to your contacts. Start utilizing Pabbly Connect to streamline your workflows today!
