Learn how to automate publishing posts from WordPress to Blogger using Pabbly Connect. Step-by-step guide for seamless integration. Navigate the automation landscape confidently with clear, structured guidance suitable for professionals regardless of prior technical experience.
1. Setting Up Pabbly Connect for WordPress to Blogger Integration
To publish your posts from WordPress to Blogger, the first step is to set up Pabbly Connect. Access your Pabbly Connect account and create a new workflow. This workflow will automate the process of transferring your content from WordPress to Blogger.
Once you are in the Pabbly Connect dashboard, click on the ‘Create New Workflow’ button. Give your workflow a name that reflects its function, such as ‘WordPress to Blogger Integration’. This will help you keep your automations organized.
2. Connecting WordPress to Pabbly Connect
After creating the workflow, the next step involves connecting your WordPress account to Pabbly Connect. Select WordPress as your trigger application. This allows Pabbly Connect to listen for new posts published on your WordPress site.
- Choose the ‘New Post’ trigger event.
- Authenticate your WordPress account by entering your website URL and login credentials.
- Test the connection to ensure that Pabbly Connect can access your WordPress site.
After successful authentication, you can set up the specific parameters for the posts you want to publish. This includes selecting post types and categories that will trigger the automation.
3. Integrating Blogger with Pabbly Connect
The next step is to connect your Blogger account to Pabbly Connect. Choose Blogger as your action application. This will allow you to publish content directly to your Blogger account once it is triggered from WordPress.
Authenticate your Blogger account by selecting it from the list of applications and logging in with your Google credentials. Make sure you grant the necessary permissions for Pabbly Connect to manage your Blogger posts.
4. Mapping Fields Between WordPress and Blogger
Now, it’s time to map the fields from your WordPress posts to Blogger. This is a crucial step in the integration process facilitated by Pabbly Connect. You need to ensure that the content from your WordPress posts is accurately reflected in your Blogger posts.
- Map the post title from WordPress to the title field in Blogger.
- Link the post content from WordPress to the content field in Blogger.
- Specify any labels or tags you want to apply to the Blogger post.
Once the fields are mapped, you can perform a test to ensure that a new post in WordPress is successfully published on Blogger. This step validates that your integration is working correctly.
5. Finalizing Your WordPress to Blogger Integration
After mapping the fields and testing the integration, it’s time to finalize your workflow in Pabbly Connect. Review all settings to ensure everything is configured correctly. Once confirmed, turn on your workflow to begin automatic posting.
Now, every time you publish a new post on WordPress, it will automatically appear on your Blogger account. This seamless integration saves you time and ensures your content reaches a wider audience without manual effort.
Using Pabbly Connect, you can efficiently automate the process of publishing posts from WordPress to Blogger. This integration allows for seamless content sharing and enhances your online presence.
