Learn how to automate publishing Instagram posts to LinkedIn using Pabbly Connect. Follow this step-by-step guide to streamline your social media management. Develop expertise in application integration and learn how to design streamlined automation workflows using proven, simplified approaches.
1. Accessing Pabbly Connect for Instagram to LinkedIn Integration
To publish Instagram posts to LinkedIn, you first need to access Pabbly Connect. Start by signing in to your existing Pabbly Connect account or create a new account if you are a first-time user. Pabbly Connect offers a free tier that allows you to perform 100 tasks monthly, making it accessible for everyone.
Once logged in, navigate to the Pabbly Connect dashboard. Here, you can create a new workflow that will automate the process of sharing your Instagram posts on LinkedIn. Follow the steps to set up your workflow effectively.
After accessing your Pabbly Connect dashboard, click on the ‘Create Workflow’ button located at the top right corner. In the dialog box that appears, name your workflow something descriptive, such as ‘Publish Instagram Post to LinkedIn’. You can also choose a folder to save this workflow for better organization.
- Select a descriptive name for your workflow.
- Choose a folder to keep your workflows organized.
- Click ‘Create’ to proceed to the next step.
Once you have created the workflow, you will be taken to a screen where you can set up triggers and actions. This is where Pabbly Connect shines, allowing you to define how your Instagram posts will trigger actions on LinkedIn.
3. Setting Up Trigger and Action for Instagram and LinkedIn
In this step, you will set up Instagram as your trigger application in Pabbly Connect. Select ‘Instagram for Business’ as the trigger app and choose the event ‘New Media Posted’. This means that every time you post something new on Instagram, it will trigger the workflow. using Pabbly Connect
Next, you will need to set LinkedIn as your action application. Choose ‘Share an Article or URL’ as the action event. This setup ensures that whenever you post on Instagram, the same content will be shared on LinkedIn automatically, streamlining your social media presence.
- Select ‘Instagram for Business’ for the trigger application.
- Choose ‘New Media Posted’ as the trigger event.
- Set LinkedIn as the action application with ‘Share an Article or URL’.
With the trigger and action set, Pabbly Connect will now automate the process of sharing new Instagram posts on LinkedIn, enhancing your marketing efforts.
4. Connecting Applications in Pabbly Connect
To successfully connect your Instagram and LinkedIn accounts, click on the ‘Connect’ button in the trigger section. After that, you will be prompted to log into your Instagram account. Ensure you have already logged in to your account in another tab for a smoother connection process.
Once connected, you will see a confirmation message indicating that Instagram is successfully linked with Pabbly Connect. Repeat this process for LinkedIn by clicking on the ‘Connect’ button in the action section and logging into your LinkedIn account. This will establish the necessary connections for automation.
After connecting both applications, it’s time to test your integration. Create a new post on Instagram, ensuring it has a caption and an image. Once published, return to Pabbly Connect and click on ‘Save and Send Test Request’. This action will check for new data from your Instagram account. using Pabbly Connect
After a few moments, you should see a response in Pabbly Connect that confirms the new post has been captured. This includes the post’s caption and image URL. Finally, to verify that the integration works, check your LinkedIn account. You should see the Instagram post shared automatically.
Now, your workflow is complete, and you can rest assured that any new Instagram post will be shared on LinkedIn without any manual effort.
In this tutorial, we demonstrated how to use Pabbly Connect to automate publishing Instagram posts to LinkedIn. By following these steps, you can streamline your social media management efficiently.
