Learn how to post WooCommerce products on your Facebook page using Pabbly Connect and Bitly in this step-by-step tutorial. Automate your marketing effortlessly! This comprehensive guide reveals exactly how to connect your applications and automate repetitive tasks — accessible for professionals of all technical backgrounds.
1. Accessing Pabbly Connect for WooCommerce Integration
To start automating your WooCommerce product posting on Facebook, you first need to access Pabbly Connect. Open your browser and search for Pabbly Connect to reach its landing page. Here, you can either sign in if you already have an account or sign up for free to get started.
Once logged in, you will be directed to your dashboard. This is where you can create workflows to automate actions between different applications. Click on the ‘Create Workflow’ button to begin setting up your integration for posting WooCommerce products on your Facebook page.
The first step in your workflow is to set up the trigger using Pabbly Connect. For this automation, select WooCommerce as your trigger application. The trigger event you need to choose is ‘New Product Created’. This event will initiate the workflow whenever a new product is added to your WooCommerce store.
- Select ‘WooCommerce’ as the trigger application.
- Choose ‘New Product Created’ as the trigger event.
Next, you will need to connect WooCommerce with Pabbly Connect. Go to your WordPress dashboard, navigate to WooCommerce settings, and find the ‘Advanced’ tab. Under the Advanced settings, locate the ‘Webhooks’ section and create a new webhook by pasting the copied URL. This establishes a connection between WooCommerce and Pabbly Connect.
3. Creating a Bitly Link for Your Product
After setting up the trigger, the next step involves creating a Bitly link for your new product using Pabbly Connect. In the action section of your workflow, select Bitly as your action application. The action event should be ‘Create Bitlink’. This will allow you to generate a short, trackable link for your WooCommerce product.
To connect Bitly with Pabbly Connect, click on ‘Add New Connection’ and authorize your Bitly account. Once connected, you will need to map the product URL from the WooCommerce response to the Bitly link creation fields.
- Select ‘Bitly’ as the action application.
- Choose ‘Create Bitlink’ as the action event.
- Map the product URL and title from WooCommerce.
By using Pabbly Connect, you can automate the process of creating a Bitly link every time a new product is added, making your marketing efforts more efficient.
4. Posting the Product to Your Facebook Page
Now that you have created a Bitly link, the final step is to post your WooCommerce product on your Facebook page using Pabbly Connect. In this action step, select Facebook Pages as your action application. The action event should be ‘Create Page Photo Post’. This allows you to share your product along with its image and a description.
Connect your Facebook account to Pabbly Connect and select the appropriate page where you want to post the product. You’ll need to map the image URL and description, which should include the Bitly link you generated earlier, ensuring that potential customers can easily access your product.
Select ‘Facebook Pages’ as the action application. Choose ‘Create Page Photo Post’ as the action event. Map the image URL and description with the Bitly link.
After setting this up, every time you add a new product to WooCommerce, Pabbly Connect will automatically create a post on your Facebook page, enhancing your product visibility without manual effort.
5. Conclusion
In this tutorial, we demonstrated how to post WooCommerce products on your Facebook page using Pabbly Connect and Bitly. By automating the process, you can save time and effectively promote your products on social media. This integration allows for seamless marketing, ensuring that every new product reaches your audience instantly.
With Pabbly Connect, you can easily manage your WooCommerce products and enhance your online presence without any coding skills. Start using Pabbly Connect today to streamline your eCommerce marketing efforts!
