Learn how to integrate Facebook and Twitter using Pabbly Connect to post the same content on both platforms seamlessly. Follow this step-by-step guide! Revolutionize your productivity approach with just a few strategic clicks. Uncover professional methods for connecting applications and creating workflows that reclaim hours of your week.
To start the integration process using Pabbly Connect, first, visit the Pabbly Connect website by typing ‘Pabbly.com/connect’ in your browser. This will take you to the landing page of the application.
On the right-hand side, you will see options to either sign in or sign up. If you are a new user, click on ‘Sign Up’ to create an account. This process is quick and grants you 100 free tasks. For existing users, click ‘Sign In’ to access your dashboard.
Once you have signed in to Pabbly Connect, navigate to the dashboard. Here, you will see the option to ‘Create Workflow’. Click on it to start setting up your integration.
A dialog box will prompt you to name your workflow. Name it something descriptive, like ‘Post on Twitter the Same Content Posted on Facebook’. After naming it, click ‘Create’. This will lead you to a new window where you can define the trigger and action for your workflow.
- Set the trigger application to Facebook.
- Choose the trigger event as ‘New Post’.
- Configure the polling time to check for new posts every 10 minutes.
After setting up these parameters, click ‘Connect’ to link your Facebook account with Pabbly Connect.
3. Connecting Your Facebook Account
When you click ‘Connect’, Pabbly Connect will prompt you to add a new connection to your Facebook account. Click on ‘Add New Connection’ and follow the prompts to authorize Pabbly Connect to access your Facebook pages.
Once authorized, you will need to specify which Facebook page you want to monitor for new posts. Select the appropriate page and decide how many posts you want to retrieve. For testing, set this to one post and click ‘Save and Send Test Request’.
- Retrieve the latest post from your selected Facebook page.
- Ensure the API response shows the correct post details.
This step confirms that Pabbly Connect is successfully pulling data from your Facebook page.
4. Connecting Your Twitter Account
Next, you will set up the action application, which is Twitter in this case. Select Twitter as your action application and choose the action event as ‘Create Tweet with Media’. Click ‘Connect’ to link your Twitter account.
Similar to the Facebook connection, you will need to authorize Pabbly Connect to access your Twitter account. After authorization, you will be prompted to enter the tweet’s content and the media URL if applicable.
Input the message for your tweet, which should mirror the Facebook post content. Enter the media file URL from the Facebook post if there is an image.
Once you have entered all necessary details, click ‘Save and Send Test Request’ to send a test tweet. This confirms that your integration is functioning correctly through Pabbly Connect.
5. Testing the Integration
To ensure everything is working as intended, create a new post on your selected Facebook page. For instance, you might post about a new offer. After posting, wait for the polling time set in Pabbly Connect, which is 10 minutes.
After the waiting period, refresh your Twitter feed. You should see the new post from Facebook automatically tweeted. This demonstrates that the integration is successfully posting the same content on Twitter as it is on Facebook.
If you encounter any issues or want to explore other integrations, visit the Pabbly Connect support forums or the official website for more information on available features.
In this tutorial, you learned how to use Pabbly Connect to automatically post the same content on Twitter whenever you create a new post on Facebook. This integration simplifies social media management, ensuring your content reaches a wider audience effortlessly.
