Learn how to integrate Razorpay with Slack to send notifications using Pabbly Connect. Step-by-step guide for seamless automation. Revolutionize your productivity approach with just a few strategic clicks. Uncover professional methods for connecting applications and creating workflows that reclaim hours of your week.
To notify a Slack channel when a Razorpay payment is received, you first need to access Pabbly Connect. Open a new tab in your browser and visit Pabbly.com/connect. This platform allows you to integrate various applications seamlessly.
Once on the Pabbly Connect homepage, you can either sign up for a new account or log in if you are an existing user. After signing in, you will be directed to the dashboard where you can manage your automation workflows. Click on the ‘Create Workflow’ button to start the integration process.
Creating a workflow in Pabbly Connect is essential for automating the notifications. After clicking ‘Create Workflow’, you will be prompted to name your workflow. Enter a suitable name, such as ‘Notify Slack Channel When Razorpay Payment is Received’ and select a folder for organization.
Once the workflow is created, you will need to set up a trigger. Click on the plus icon to select Razorpay as your trigger application. Choose the event as ‘Payment Captured’ to initiate the workflow whenever a payment is successful. After selecting the event, click on the connect button to proceed.
- Open Pabbly Connect and create a new workflow.
- Select Razorpay as the trigger application.
- Choose the event as ‘Payment Captured’.
After setting up the trigger, Pabbly Connect will provide you with a webhook URL. Copy this URL as it will be used to connect Razorpay to Pabbly Connect.
3. Configuring Razorpay with Pabbly Connect
Now that you have the webhook URL from Pabbly Connect, log into your Razorpay account. Navigate to the ‘Account and Settings’ section and find the ‘Webhooks’ option. Here, you will add a new webhook using the URL you copied earlier.
In the webhook settings, you will need to specify the event type as ‘Payment Captured’. This ensures that Razorpay sends a notification to Pabbly Connect only when a payment is successfully captured. After entering the required details, save the webhook configuration.
- Log into your Razorpay account.
- Navigate to the ‘Webhooks’ section.
- Paste the webhook URL from Pabbly Connect.
With the webhook set up, your Razorpay account is now connected to Pabbly Connect. This allows Pabbly Connect to receive notifications whenever a payment is captured.
4. Setting Up Slack Notifications Using Pabbly Connect
After configuring Razorpay, the next step is to set up Slack notifications through Pabbly Connect. In your workflow, click on the plus icon again to add an action application. Select Slack as your action app and choose ‘Send Channel Message’ as the event.
You will need to connect your Slack account to Pabbly Connect. Click on ‘Connect with Slack’ and follow the prompts to authorize the connection. Once connected, select the channel where you want to send the payment notifications.
Add Slack as an action application in Pabbly Connect. Choose ‘Send Channel Message’ as the action event. Connect your Slack account to Pabbly Connect.
With the Slack channel selected, you can now customize the message that will be sent. Use dynamic fields from Razorpay to include payment details in the message. This ensures that every notification is personalized and relevant.
5. Testing the Integration Between Razorpay and Slack
To ensure that everything is set up correctly, it’s time to test the integration using Pabbly Connect. Make a test payment through Razorpay to trigger the webhook. Once the payment is successful, Pabbly Connect will capture the payment details and send a notification to your designated Slack channel.
Check your Slack channel for the notification message. It should contain all the relevant details about the payment, confirming that the integration is working as intended. If you receive the message, your setup is complete and functioning perfectly.
This automation significantly reduces manual efforts, ensuring that your team is informed of successful payments in real-time. With Pabbly Connect, you can streamline your payment notifications efficiently.
By following this tutorial, you have successfully learned how to notify a Slack channel when a Razorpay payment is received using Pabbly Connect. This integration allows for real-time updates on payment statuses, enhancing communication within your team. Automating such processes saves time and improves operational efficiency.
