Learn how to automate Typeform submissions to Stackby using Pabbly Connect. This step-by-step tutorial covers all the necessary actions and UI elements. This comprehensive guide reveals exactly how to connect your applications and automate repetitive tasks — accessible for professionals of all technical backgrounds.
1. Access Pabbly Connect for Typeform to Stackby Integration
To start integrating Typeform submissions into Stackby, first, access Pabbly Connect by navigating to the URL Pabbly.com/connect. This platform allows you to automate workflows seamlessly.
Once on the Pabbly Connect page, you can either log in if you already have an account or sign up for free. Signing up provides you with 100 free tasks monthly, which is great for practicing your automation workflows.
After logging into Pabbly Connect, click on ‘Create New Workflow’ to initiate the integration process. Name your workflow something descriptive, like ‘Typeform to Stackby Integration’.
- Click on ‘Create’.
- Select ‘Typeform’ as the trigger application.
- Choose ‘New Entry’ as the trigger event.
These steps will set up the trigger for your workflow, allowing Pabbly Connect to listen for new submissions in Typeform.
3. Connecting Typeform to Pabbly Connect
In this step, you will connect Typeform to Pabbly Connect. Click on ‘Connect’ and then select ‘Add New Connection’. You will be prompted to authorize Pabbly Connect to access your Typeform account.
Once authorized, select the specific Typeform you wish to use from the dropdown menu. Ensure you have a form ready, such as a registration form that collects data like first name, last name, email, and contact number.
4. Setting Up Stackby to Receive Data
Now, you need to set up Stackby as the action application in your workflow. Select Stackby, then click on ‘Connect’ and ‘Add New Connection’. You will need your Stackby API key for this step.
- Log into your Stackby account.
- Go to your profile and find the API key.
- Copy the API key and paste it into Pabbly Connect.
This will link your Stackby account to Pabbly Connect, allowing it to create new rows automatically whenever a Typeform submission is received.
5. Mapping Data from Typeform to Stackby
After connecting both applications, you will need to map the data fields from Typeform to Stackby. This is crucial for ensuring the correct information is transferred. using Pabbly Connect
For instance, map the first name, last name, email, and contact number from Typeform to their respective fields in Stackby. This mapping is a one-time setup, allowing future submissions to be added automatically.
By using Pabbly Connect, you can seamlessly automate the process of adding Typeform submissions to Stackby. This integration saves time and ensures that your data is organized efficiently. Start automating today!
