Learn how to seamlessly add JustDial enquiries to ActiveCampaign for email automation using Pabbly Connect in this step-by-step tutorial. Eliminate manual repetitive tasks from your workflow. Discover proven automation methods with intuitive steps designed for efficiency-minded professionals.
To start the integration process, access Pabbly Connect by visiting the official website. Simply search for ‘Pabbly.com/connect’ in your browser to reach the landing page. Once there, you will see options to sign in or sign up for free, depending on whether you are an existing user or a new user.
For existing users, click on the ‘Sign In’ button. This will direct you to your Pabbly Connect dashboard, where you can begin creating your workflows. Remember, Pabbly Connect is the automation tool that will connect JustDial and ActiveCampaign seamlessly.
Once you are logged into your Pabbly Connect account, click on the ‘Create Workflow’ button to initiate a new integration. You will be prompted to select a workflow builder. Choose the new workflow builder for a modern interface, which is ideal for creating efficient automation.
Next, enter a name for your workflow and select a folder to save it in. You can create new folders if needed. After naming your workflow, click the ‘Create’ button. This will take you to the workflow window where you will set up the trigger and action for your integration.
- Click on the ‘Add Trigger’ button.
- Select JustDial as your trigger application.
- Choose ‘New Leads’ as the trigger event.
With these steps completed, you are now ready to set up the connection between JustDial and Pabbly Connect.
3. Setting Up JustDial to Send Data to Pabbly Connect
After selecting JustDial as your trigger application, click on the ‘Connect’ button. You will receive a webhook URL from Pabbly Connect. This URL is crucial as it allows JustDial to send lead details to your Pabbly Connect workflow.
To complete the integration, copy the webhook URL and contact your JustDial account manager. Since JustDial does not allow users to add webhook URLs directly, you need to provide this URL to them. Once they add it to your account, Pabbly Connect will automatically receive lead details whenever a new lead is generated on JustDial.
4. Adding ActiveCampaign as an Action in Pabbly Connect
Now that you have successfully set up JustDial to send data to Pabbly Connect, it’s time to add ActiveCampaign as the action application. Click on the ‘Add Action Step’ button and select ActiveCampaign from the list of applications.
For the action event, choose ‘Create or Update a Contact’ and click ‘Connect’. You will need to provide your ActiveCampaign API URL and key. To find these, go to your ActiveCampaign account settings, navigate to the Developer section, and copy the required information.
- Paste the API URL in Pabbly Connect without the ‘https://’ prefix.
- Enter your API key from ActiveCampaign.
- Click on ‘Save’ to establish the connection.
After saving, you can now map the lead details from JustDial to the fields in ActiveCampaign.
5. Mapping Fields and Finalizing the Integration
With the connection established, you will see fields for email, first name, last name, etc. You can map these fields to automatically insert data from JustDial into ActiveCampaign. Mapping allows the data to be dynamic, meaning it will change with each new lead. using Pabbly Connect
Fill in the required fields by selecting the corresponding mapped data from the JustDial response. For instance, map the first name, last name, email, and phone number. You can also assign a tag, such as ‘New Leads’, for better organization in ActiveCampaign.
Once you have completed the mapping, click on ‘Save and Send Test Request’. This will create or update a contact in your ActiveCampaign account using the details received from JustDial. You should see a confirmation message indicating that the contact has been successfully created.
In this tutorial, we demonstrated how to integrate JustDial enquiries with ActiveCampaign using Pabbly Connect. By following these steps, you can automate the process of adding leads to your email campaigns, enhancing your lead nurturing efforts. Embrace automation with Pabbly Connect to streamline your business processes today!
