Learn how to automate adding HubSpot contacts to Sendinblue using Pabbly Connect with this step-by-step tutorial. Streamline your CRM and email marketing processes now! Implement the precise methodologies leading organizations use to automate repetitive tasks, illustrated with practical examples designed for immediate application.
1. Setting Up Pabbly Connect for HubSpot and Sendinblue Integration
In this section, we will discuss how to set up Pabbly Connect to automate the process of adding new HubSpot contacts to Sendinblue. First, navigate to the Pabbly Connect dashboard after signing up.
To create a new workflow, click on the ‘Create Workflow’ button. Name your workflow, for example, ‘HubSpot to Sendinblue Integration’ and then click on ‘Create’. This will open the workflow interface where you can set up your triggers and actions.
2. Configuring HubSpot as a Trigger in Pabbly Connect
The next step involves setting up HubSpot as the trigger app in Pabbly Connect. In the trigger window, search for HubSpot and select it. Choose the trigger event as ‘New Contact Added’ from the dropdown menu.
- Select HubSpot from the app list.
- Choose the trigger event as ‘New Contact Added’.
- Click ‘Connect’ and then ‘Add New Connection’.
- Authorize your HubSpot account.
Once authorized, you need to select the properties you want to retrieve from HubSpot when a new contact is created. For example, select the first name, last name, email, and mobile number. After selecting these, click on ‘Save and Send Test Request’ to retrieve the latest contact details.
3. Creating a New Contact in HubSpot
Before testing the workflow, you need to create a new contact in HubSpot. Go to the Contacts section in HubSpot and click on ‘Create Contact’. Fill in the necessary details such as first name, last name, email, and phone number.
After entering the details, click on ‘Create’. This action will trigger Pabbly Connect to capture the new contact information. Make sure to include all required fields as specified in the previous step.
4. Setting Up Sendinblue as an Action in Pabbly Connect
Now, you need to configure Sendinblue as the action app in Pabbly Connect. In the action window, search for Sendinblue and select it. Choose the action event as ‘Create or Update Contact’.
- Select Sendinblue from the app list.
- Choose the action event as ‘Create or Update Contact’.
- Connect your Sendinblue account by entering the API key.
To get the API key, log in to your Sendinblue account, navigate to the SMTP & API section, and generate a new API key. Copy this key and paste it into Pabbly Connect. Once connected, map the email address, first name, and last name fields from HubSpot to Sendinblue.
After mapping the necessary fields, click on ‘Save and Send Test Request’ in Pabbly Connect. This will send the contact information to Sendinblue, creating a new subscriber.
To verify the integration, go to your Sendinblue account and check the Contacts section for the newly added contact. Every time a new contact is created in HubSpot, Pabbly Connect will automatically add that contact to Sendinblue as well.
In this tutorial, we demonstrated how to use Pabbly Connect for integrating HubSpot with Sendinblue to automate contact management. This integration streamlines the process, ensuring that every new HubSpot contact is instantly added to Sendinblue.
By following these steps, you can enhance your CRM and email marketing efforts effectively using Pabbly Connect. Start automating your workflows today!
