Learn how to automatically add HubSpot contacts to Mailercloud using Pabbly Connect. Follow this detailed tutorial for seamless integration. Learn to create powerful connections between your critical applications without requiring specialized programming knowledge or extensive technical background.
1. Setting Up Pabbly Connect for HubSpot and Mailercloud Integration
To integrate HubSpot and Mailercloud, the first step is to access Pabbly Connect. This platform allows you to automate the process of adding new contacts from HubSpot to your Mailercloud contact list seamlessly. Begin by visiting the Pabbly website and navigating to the Pabbly Connect product page.
Once on the Pabbly Connect page, you can sign up for a free account if you are a new user. After creating your account, log in to access the dashboard where you can create your automation workflows.
In this section, you will create a workflow specifically for integrating HubSpot with Mailercloud using Pabbly Connect. Click on the plus sign to create a new workflow and name it ‘HubSpot to Mailercloud Integration’. This name helps you easily identify the workflow later.
- Click on the plus icon to create a new workflow.
- Proceed to set the trigger and action for the workflow.
After naming your workflow, you will see a trigger window. This is where you will select HubSpot as your app and choose the trigger event, which is ‘New Contact Added’. This will allow Pabbly Connect to capture new contacts created in HubSpot.
3. Connecting HubSpot to Pabbly Connect
The next step is to connect your HubSpot account to Pabbly Connect. Click on the ‘Connect’ button and then select ‘Add New Connection’. You will need to provide your HubSpot API key, which can be found in your HubSpot settings under the integrations section.
Once you have entered the API key, click on ‘Save’. This establishes a connection between HubSpot and Pabbly Connect, allowing the platform to retrieve contact details whenever a new contact is created in HubSpot.
4. Adding Contacts to Mailercloud Using Pabbly Connect
Now that your HubSpot account is connected, the next step is to set up the action that will add contacts to Mailercloud. In the action window, select Mailercloud as the application and choose the action event ‘Add Contact to List’. This action allows you to automatically add new contacts captured from HubSpot to your Mailercloud contact list. using Pabbly Connect
- Select Mailercloud as the application in the action window.
- Choose the action event to add the contact.
- Connect your Mailercloud account using the API key.
After connecting Mailercloud with Pabbly Connect, you will need to specify the contact list where the new HubSpot contacts should be added. Select the appropriate list from your Mailercloud account, ensuring that it corresponds to the contacts being added from HubSpot.
5. Testing the Integration Between HubSpot and Mailercloud
With the workflow set up, it’s time to test the integration. Create a new contact in your HubSpot account to see if it automatically appears in your Mailercloud contact list. After creating the contact, return to Pabbly Connect and click on ‘Save and Send Test Request’. using Pabbly Connect
Once you initiate the test, check your Mailercloud account to confirm that the new contact has been added successfully. If everything is set up correctly, you should see the new contact listed in your Mailercloud account almost immediately.
In this tutorial, we demonstrated how to use Pabbly Connect to automate the process of adding HubSpot contacts to Mailercloud. By following the steps outlined, you can seamlessly integrate these two powerful applications and enhance your marketing efforts. This integration ensures that your contact lists are always up-to-date with minimal manual effort.
