Learn how to automate adding ClickFunnels contacts to ActiveCampaign using Pabbly Connect. Follow our step-by-step tutorial for seamless integration. Build sophisticated automated workflows in less time than you think. This guide translates complex integrations into straightforward steps for immediate implementation.
1. Setting Up Pabbly Connect for ClickFunnels and ActiveCampaign Integration
To start integrating ClickFunnels with ActiveCampaign, you need to access Pabbly Connect. First, sign up for a free account on Pabbly Connect if you haven’t already. Once logged in, navigate to the dashboard where you can create a new workflow.
Click on the ‘Create Workflow’ button and name your workflow, for instance, ‘ClickFunnels to ActiveCampaign’. After naming, click on ‘Create’. This action opens two windows: the trigger window and the action window, which are essential for setting up your automation.
2. Configuring the Trigger for ClickFunnels in Pabbly Connect
In the trigger window, search for ClickFunnels and select it. From the dropdown, choose the trigger event as ‘New Contact Created’. This step is crucial because it sets the automation to trigger whenever a new contact is added to ClickFunnels. using Pabbly Connect
- Select ClickFunnels as the app in Pabbly Connect.
- Choose ‘New Contact Created’ as the trigger event.
- Copy the provided webhook URL from Pabbly Connect.
Now, head over to your ClickFunnels account. Go to the settings of your funnel, find the Webhooks section, and click on ‘Add New Endpoint’. Name it something like ‘Pabbly’. Paste the copied webhook URL in the URL section and select ‘Contact.Created’ as the event type. Click ‘Create Endpoint’ to finalize the setup.
3. Testing ClickFunnels Integration with Pabbly Connect
After configuring the webhook, it’s time to test the integration. Go back to your ClickFunnels funnel and create a new contact by filling out the opt-in form. For example, enter a name like ‘Test Pabbly’, an email address, and a phone number, then click the ‘Click to Sign Up’ button.
Once the contact is created, return to Pabbly Connect and check the response in your workflow. You should see the newly created contact’s details populated in the response section. This confirms that the integration between ClickFunnels and Pabbly Connect is functioning correctly.
4. Adding the ClickFunnels Contact to ActiveCampaign via Pabbly Connect
Now that the ClickFunnels integration is working, let’s add the new contact to ActiveCampaign. In the action window of Pabbly Connect, search for ActiveCampaign and select it. Choose the action event as ‘Create a Contact’. This action will allow you to add the new contact details directly into your ActiveCampaign account.
To connect your ActiveCampaign account, click ‘Connect’ and select ‘Add New Connection’. You will need your ActiveCampaign API key and URL. To find these, go to your ActiveCampaign dashboard, click on ‘Settings’, then ‘Developers’. Copy the API URL and API key, and paste them into Pabbly Connect.
5. Mapping Data and Final Testing in Pabbly Connect
After successfully connecting ActiveCampaign, you need to map the data from ClickFunnels to ActiveCampaign. In the email field, select the email response from ClickFunnels. Repeat this process for the first name, last name, and phone number fields by mapping them to the corresponding responses from ClickFunnels.
Once all fields are mapped, click on ‘Save and Send Test Request’. If everything is set up correctly, you should see a positive response indicating that the contact has been added to ActiveCampaign. To confirm, check your ActiveCampaign contacts section for the new entry.
To further validate the automation, create another contact in ClickFunnels and ensure that it appears in ActiveCampaign. This will demonstrate that your Pabbly Connect integration is working seamlessly, allowing you to automate contact management between ClickFunnels and ActiveCampaign.
In this tutorial, we demonstrated how to integrate ClickFunnels with ActiveCampaign using Pabbly Connect. By following the steps outlined, you can automate the process of adding new contacts from ClickFunnels to ActiveCampaign effortlessly. This integration enhances your marketing efficiency and ensures that your contact lists are always up-to-date.
