Learn how to integrate GoHighLevel with Telegram for instant notifications using Pabbly Connect. Step-by-step tutorial with detailed instructions. Discover hidden automation capabilities within your existing tools. This guide shows you how to connect your essential applications and permanently eliminate redundant manual processes.
To start the integration process, visit Pabbly Connect by typing in ‘Pabbly.com/connect’ in your browser. This will take you to the Pabbly Connect dashboard, where you can log in or create a new account.
Creating an account is free and takes only a couple of minutes. Once logged in, you will see options to create new workflows, which is essential for setting up the integration with GoHighLevel and Telegram.
After logging into Pabbly Connect, click on the ‘Create New Workflow’ button. You will be prompted to name your workflow; for this tutorial, name it ‘Go High Level to Telegram’.
- Choose a relevant name for your workflow.
Once created, you will be presented with two options: Trigger and Action. The Trigger is the event that starts the workflow, and the Action is what happens as a result of that trigger. For this integration, you will set GoHighLevel as the Trigger.
3. Setting Up the Trigger for GoHighLevel
In the Trigger section of your workflow, select Pabbly Connect and choose ‘GoHighLevel’ as the application. Then, select ‘Customer Replied’ as the trigger event.
Next, you will see a webhook URL provided by Pabbly Connect. This URL will be used to connect your GoHighLevel account to the Pabbly Connect workflow. Follow these steps:
- Log into your GoHighLevel account.
- Navigate to the ‘Triggers’ section and click ‘Add Trigger’.
- Paste the webhook URL from Pabbly Connect into the appropriate field.
Once done, activate the trigger and save your settings. This setup will ensure that whenever a customer replies, the information is sent to your Pabbly Connect workflow.
4. Configuring the Action to Send Notifications to Telegram
Now that you have set up the trigger, the next step is to configure the action to send notifications to Telegram. In the Action section, select Pabbly Connect and then choose ‘Telegram’ as the application.
For the action event, select ‘Send Text Message’. You will need to connect your Telegram bot to Pabbly Connect. To do this, you will require the bot token, which you can obtain via the BotFather on Telegram. Follow these steps:
Start a chat with BotFather on Telegram. Create a new bot and copy the token provided. Paste the token into Pabbly Connect to establish the connection.
After connecting, you will also need to provide the chat ID of the Telegram group where notifications will be sent. Make sure your bot is an admin in this group for it to send messages successfully.
5. Testing the Integration for Successful Notifications
With the setup complete, it’s time to test the integration. Send a test email to the GoHighLevel account and reply to that email. This action should trigger the workflow you created in Pabbly Connect.
Check your Telegram group to see if the notification appears. The message should contain details about the customer’s issue, allowing your team to respond promptly.
By using Pabbly Connect, you can automate notifications effectively, enhancing your team’s responsiveness and customer service capabilities. This integration streamlines communication and ensures that your team is always updated with customer inquiries.
Integrating GoHighLevel with Telegram using Pabbly Connect allows you to receive instant notifications for customer replies. This automation enhances team collaboration and improves customer service efficiency.
