Learn how to generate SEO keywords using Pabbly Connect and an AI agent. This detailed tutorial covers the integration process with Google Sheets and OpenAI.
1. Accessing Pabbly Connect for SEO Keywords
To start generating SEO keywords using an AI agent, you need to access Pabbly Connect. Begin by visiting the Pabbly Connect landing page at pabby.com/connect. Here, you will find options to sign in or sign up for free.
If you are a new user, select the ‘Sign up for free’ option to get started with 100 tasks free every month. Existing users should click on ‘Sign in’ to access their dashboard. After signing in, locate and click on the ‘Access Now’ button under Pabbly Connect to begin your automation journey.
Once you have accessed Pabbly Connect, the next step is to create a new workflow. Click on the ‘Create Workflow’ button, where you will be prompted to name your workflow. For this tutorial, name it ‘How to Generate SEO Keywords using AI Agent’ and select the folder to save it in.
- Click on the ‘Create’ button to open the workflow window.
- In this window, you will set up a trigger and action for your automation.
- Select Google Sheets as your trigger application.
After selecting Google Sheets, set the trigger event to ‘New or Updated Spreadsheet Row’. This setup allows Pabbly Connect to monitor your Google Sheets for any new entries, which will trigger the automation.
3. Setting Up Google Sheets Integration
To connect Google Sheets with Pabbly Connect, you need to configure the webhook. After selecting your trigger event, you will receive a webhook URL. Copy this URL as it will be used in Google Sheets.
Open your Google Sheets and navigate to Extensions > Add-ons > Get Add-ons. Search for the Pabbly Connect Webhooks extension and install it. After installation, refresh your spreadsheet to ensure the extension appears in the Extensions menu.
- Go to Extensions > Pabbly Connect Webhooks > Initial Setup.
- Paste the copied webhook URL and set the trigger column (for example, A).
- Click on ‘Submit’ to successfully configure the setup.
Once the setup is complete, Pabbly Connect will wait for a webhook response whenever a new row is added to your sheet. This connection is crucial for the automation to function effectively.
4. Generating SEO Keywords with AI Agent
Now that Google Sheets is connected to Pabbly Connect, the next step is to generate SEO keywords using the AI agent, OpenAI. Select OpenAI as your action application and choose the action event as ‘Chat GPT’.
You will be prompted to either select an existing connection or add a new one. If adding a new connection, you will need an OpenAI API key. Visit the OpenAI API key page, create a new secret key, and copy it back to Pabbly Connect.
Select GPT-4 as your AI model. Enter your prompt for keyword generation. Map the topic from the Google Sheets response to ensure dynamic data.
After entering the prompt, click on ‘Save and Send Test Request’. This action will send a request to OpenAI to generate SEO keywords based on your provided topic, completing this part of the automation.
5. Updating Google Sheets with Generated Keywords
After generating SEO keywords, the final step involves updating your Google Sheets with the results. In Pabbly Connect, add another action step and select Google Sheets again, this time choosing the action event ‘Update Row’.
You will need to connect your Google Sheets account once more. After selecting your spreadsheet and sheet, map the row index from the previous step. Then, map the keyword suggestion, search intent, keyword type, and suggested use from the OpenAI response.
Click on ‘Save and Send Request’ to update your sheet. Check your Google Sheets to confirm that the details have been added successfully. This step finalizes the workflow, allowing automation to run seamlessly.
With this setup, every time you add a topic to your Google Sheets, Pabbly Connect will automatically generate SEO keywords and update the sheet without any manual intervention, streamlining your SEO process.
In this tutorial, we explored how to generate SEO keywords using Pabbly Connect and an AI agent. By integrating Google Sheets and OpenAI, you can automate the keyword generation process efficiently. This automation not only saves time but also enhances your SEO strategy significantly.
