Learn to generate images using AI Agent and save them in Google Drive through Pabbly Connect in this step-by-step tutorial. Discover hidden automation capabilities within your existing tools. This guide shows you how to connect your essential applications and permanently eliminate redundant manual processes.
1. Setting Up Pabbly Connect for Image Generation
To start generating images using AI Agent, you first need to set up Pabbly Connect. This platform will facilitate the integration between Google Sheets and the AI Agent. Begin by signing up for a free account on the Pabbly Connect website.
Once logged in, navigate to the dashboard and click on the ‘Create Workflow’ button. You can name your workflow, for example, ‘AI Agent for Image Generation’. This name helps in identifying the workflow later. After naming, select a folder in your Pabbly account where you want to save this workflow and click ‘Create’.
2. Connecting Google Sheets with Pabbly Connect
The next step involves connecting your Google Sheets with Pabbly Connect. In the trigger step, search for Google Sheets and select it. Choose the trigger event as ‘New or Updated Spreadsheet Row’. This ensures that every time a new row is added or updated in your Google Sheet, the workflow is triggered.
- Select Google Sheets as the app for the trigger.
- Set the trigger event to ‘New or Updated Spreadsheet Row’.
Next, go to your Google Sheet, click on ‘Extensions’, then ‘Add-ons’, and select ‘Get Add-ons’. Search for the Pabbly Connect Webhooks add-on and install it. After installation, refresh your Google Sheet and set up the webhook URL in the add-on. This will establish a connection between your Google Sheet and Pabbly Connect.
3. Creating an AI Agent to Generate Images
Now that your Google Sheets is connected to Pabbly Connect, you can create the AI Agent. This involves setting up the action steps that will generate images based on the data entered in your spreadsheet. Start by adding a filter condition in your workflow to check if the status is set to ‘Generate’. If it is, the workflow will proceed to generate the image.
To do this, add a filter step in Pabbly Connect. Set the filter condition to check if the status equals ‘Generate’. If the condition is met, proceed to the next step where you will connect to an AI image generation platform, such as OpenAI.
- Add a filter step to check the status.
- Connect to OpenAI to generate the image.
- Map the character and scene descriptions from Google Sheets into the prompt for image generation.
After setting up the filter and connecting to the AI platform, you will configure the parameters for image generation, including the prompt, size, and quality. This setup ensures that the AI generates images based on the specific details provided in your Google Sheet.
4. Uploading Generated Images to Google Drive
Once the image is generated, the next step is to upload it to Google Drive using Pabbly Connect. Add another action step and select Google Drive. Choose the action event as ‘Upload a File’. Connect your Google Drive account to Pabbly Connect by signing in with your Google credentials.
In this step, you will need to map the image URL received from OpenAI to the Google Drive upload action. Specify the folder ID where you want to save the image and ensure to set the file name correctly, including the appropriate file extension. This will ensure that the image is stored correctly in your Google Drive.
5. Updating Google Sheets with Image Links
The final step in this workflow is to update your Google Sheet with the link to the uploaded image. Add another action step in Pabbly Connect and select Google Sheets again. Choose the action event as ‘Update Row’. This will allow you to modify the row where the image link should be added.
Map the row index received from the trigger step and specify the column where the image link will be stored. After completing this setup, the workflow will automatically update your Google Sheet with the link to the newly generated image in Google Drive.
By following these steps, you can successfully generate images using AI Agent, save them in Google Drive, and update your Google Sheet with the image links, all facilitated by Pabbly Connect.
In this tutorial, we explored how to generate images using AI Agent and save them in Google Drive through Pabbly Connect. By integrating Google Sheets, an AI image generation platform, and Google Drive, you can automate your image creation process efficiently.
