Learn how to automate the creation of educational carousel posts from your blog content using Pabbly Connect. Follow our detailed tutorial for seamless integration. Navigate the automation landscape confidently with clear, structured guidance suitable for professionals regardless of prior technical experience.
1. Accessing Pabbly Connect to Start Your Automation
To begin generating educational carousel posts from blog content, the first step is accessing Pabbly Connect. This platform is crucial for integrating your WordPress account with other applications like Google Docs and OpenAI.
Navigate to Pabbly Connect by entering ‘Pabbly.com/connect’ in your browser. If you’re a new user, click on ‘Sign Up Free’ to create an account. Existing users can simply click ‘Sign In’ to access their dashboard. Once logged in, you will see the Pabbly Connect dashboard where you can create your automation workflows.
After logging in, the next step is to create a new workflow within Pabbly Connect. Click on the ‘Create Workflow’ button and name your workflow something like ‘Generate Educational Carousel Posts from Blog Content Using AI Agent’. This name helps identify the workflow later.
- Select a folder to save your workflow, such as ‘Automations’.
- Click on the ‘Create’ button to initiate your workflow.
Once your workflow is created, you will need to define the trigger and action steps. The trigger will be the event that starts the automation, and the action will be what happens as a result.
3. Setting Up the Trigger with WordPress
In this section, you will set up the trigger for your workflow using WordPress. Select WordPress as your trigger application and choose the event ‘New Post Published’. This means that every time you publish a new blog post, it will trigger the workflow in Pabbly Connect.
You will be given a webhook URL that you need to copy. Go to your WordPress account, install the WP Webhooks plugin, and paste the copied webhook URL into the settings. Ensure that you select the post type as ‘Post’ and the post status as ‘Published’ to capture the published posts correctly.
4. Connecting OpenAI to Generate Carousel Post Ideas
With the trigger set up, the next step is to connect OpenAI to Pabbly Connect. In the action step, select OpenAI as your application and choose the action event ‘Start GPT Task’. This action will utilize AI to generate carousel post ideas based on the content of your blog post.
- Enter your API token from your OpenAI account to connect.
- Select the model you want to use, such as GPT-4 Mini.
After setting up the connection, you will need to enter a prompt that instructs OpenAI on how to generate the carousel content. Use the permalink of your blog post to ensure the generated content is relevant.
5. Finalizing the Process with Google Docs Integration
Finally, to store the generated carousel post ideas, you will connect Google Docs to Pabbly Connect. In this action step, select Google Docs and choose the action event ‘Create a Blank Document’. This will create a new document in your Google Docs account whenever the workflow is triggered.
After creating the document, you will need to append the generated carousel content into this document. Select the same Google Docs application, but this time choose ‘Append a Paragraph to a Document’. Map the document ID from the previous step and insert the generated content from OpenAI.
Once everything is set up, you can test the workflow by publishing a new blog post in WordPress. Check your Google Docs to see the newly created document with the carousel post ideas.
In this tutorial, we demonstrated how to use Pabbly Connect to automate the generation of educational carousel posts from your blog content. By integrating WordPress, OpenAI, and Google Docs, you can streamline your content creation process and enhance your social media presence effortlessly.
