Learn how to automatically enroll users in Go4clic on successful Stripe payments using Pabbly Connect. Follow our step-by-step guide for seamless integration. Implement the precise methodologies leading organizations use to automate repetitive tasks, illustrated with practical examples designed for immediate application.
1. Accessing Pabbly Connect for Stripe and Go4clic Integration
In this section, we will explore how to access Pabbly Connect to set up the integration between Stripe and Go4clic. Begin by visiting the Pabbly website where you will find options to sign in or sign up for free. Signing up provides you with free tasks every month, so don’t forget to take advantage of this offer.
Once signed in, navigate to the top right corner where you will see a button labeled ‘Create Workflow’. Click on it, and when prompted, name your workflow something descriptive like ‘Stripe to Go4clic’. This naming convention helps you easily identify the integration later.
2. Setting Up the Trigger Event in Pabbly Connect
The next step involves setting up the trigger event in Pabbly Connect. Choose Stripe as your trigger application. For the trigger event, select ‘New Charge’. This event will activate whenever a payment is successfully made through Stripe, which is essential for enrolling users in Go4clic.
- Select ‘Stripe’ from the application list.
- Choose ‘New Charge’ as the trigger event.
- Pabbly Connect will generate a webhook URL for you.
Copy this webhook URL, as you will need to paste it into your Stripe dashboard to connect the two applications. This URL acts as a bridge between Stripe and Pabbly Connect, enabling seamless data transfer.
3. Configuring Stripe Webhook Settings
In this section, we will configure the webhook settings in Stripe to ensure it communicates with Pabbly Connect. Log into your Stripe account and navigate to the webhooks section from the dashboard. Click on ‘Add Endpoint’ and paste the webhook URL you copied earlier.
For the event to listen to, select ‘Charge Succeeded’. This means that every time a charge is successful, it will trigger the workflow in Pabbly Connect. After adding the endpoint, you should see a confirmation that the webhook has been successfully created.
4. Testing the Integration with a Dummy Payment
To confirm that everything is set up correctly, you need to test the integration using Pabbly Connect. Switch to test mode in Stripe and create a dummy payment. After completing the payment process, return to Pabbly Connect to see if it has captured the response.
You should see the billing details, including the email address and name of the user who made the payment. This step is crucial as it verifies that your Stripe and Pabbly Connect integration is working properly before proceeding to enroll the user in Go4clic.
5. Enrolling Users in Go4clic
The final step is to enroll users in Go4clic on successful Stripe payments using Pabbly Connect. Select Go4clic as the action application and choose the ‘Enroll User’ action event. Connect your Go4clic account by providing the API key, which you can generate from your Go4clic account settings.
Map the necessary fields such as email, first name, and last name from the Stripe response into the Go4clic enrollment form. This ensures that all user data is accurately captured and transferred. Once all fields are mapped, click on ‘Save and Send Test Request’ to complete the process.
After successfully enrolling a user, you can verify in your Go4clic account that the user has been added. This confirms that your integration between Stripe and Go4clic via Pabbly Connect is functioning as intended.
In this tutorial, we explored how to enroll users in Go4clic on successful Stripe payments using Pabbly Connect. By following these steps, you can automate the enrollment process efficiently and ensure a seamless experience for your users. With Pabbly Connect, integrating multiple applications becomes a breeze, enhancing your workflow and productivity.
