Learn how to automate user enrollment in Go4clic using Pabbly Connect with successful Razorpay payments. Step-by-step guide included. Discover how to seamlessly connect your essential tools through accessible instructions that make powerful automation available to professionals at every skill level.
To begin the process of enrolling users in Go4clic on successful Razorpay payments, you need to access Pabbly Connect. Start by visiting the Pabbly website where you will find options to sign in or sign up for a free account. Signing up will give you free tasks every month, which is beneficial for testing.
Once logged in, navigate to the Pabbly Connect dashboard. Click on the ‘Create Workflow’ button located at the top right corner. Name your workflow, for example, ‘Razorpay to Go4clic’. This sets the stage for your integration process, ensuring that Pabbly Connect is the central platform managing your workflow.
2. Setting Up the Trigger Event in Pabbly Connect
In this step, you will configure the trigger event in Pabbly Connect. Select Razorpay as your trigger application. For the trigger event, choose ‘Payment Captured’. This event will activate when a payment is successfully made on Razorpay.
- Select Razorpay as the trigger application.
- Choose ‘Payment Captured’ as the trigger event.
- Copy the generated webhook URL.
Next, log into your Razorpay account and navigate to the Webhooks section under Settings. Here, you will add a new webhook using the URL you copied from Pabbly Connect. This step is crucial as it connects Razorpay to Pabbly Connect, enabling it to send data when a payment is captured.
3. Testing the Connection Between Razorpay and Pabbly Connect
After setting up the webhook, you need to test the connection to ensure everything is functioning correctly. In your Razorpay dashboard, create a test payment. This step is essential as it allows Pabbly Connect to receive a webhook response and verify the integration.
Once you complete the test payment, return to Pabbly Connect. You should see the captured payment details, including the amount and customer information. This confirms that Razorpay is successfully communicating with Pabbly Connect.
4. Enrolling Users in Go4clic
Now that the connection is verified, the next step is to enroll users in Go4clic. In Pabbly Connect, add an action step and select Go4clic as the action application. Choose the ‘Enroll User’ action event to proceed with user enrollment.
- Select Go4clic as the action application.
- Choose ‘Enroll User’ as the action event.
- Map the required fields such as email and course ID.
To map the email, select the customer’s email from the Razorpay payment details. For the course ID, retrieve it from the URL of the course you are enrolling the user in. This mapping ensures that when a payment is captured, the user’s information is sent to Go4clic through Pabbly Connect.
5. Finalizing the Integration and Confirmation
After mapping all necessary fields, save your settings in Pabbly Connect and perform a test request. This final test will confirm that the user is successfully enrolled in Go4clic. You should receive a response indicating that the user has been added.
To verify the enrollment, check your Go4clic account for the newly enrolled user. You should see the user listed with their email and name, confirming that the integration between Razorpay and Go4clic via Pabbly Connect is complete. This automation streamlines your user enrollment process, making it efficient and reliable.
In this tutorial, we explored how to automate user enrollment in Go4clic using Pabbly Connect with successful Razorpay payments. By following these steps, you can streamline your enrollment process and enhance user experience.
